Both headlights blown!
Jake
On the way to work this morning I noticed that I only had one headlight working. I meant to have a look at it later but I forgot. I've just been to go out, put the lights on and bugger me, the other one came on for like one second and then went out as well!
I've checked the two 15 Amp fuses and they're both fine so I guess the bulbs have blown.
What would cause that?
They're quite new bulbs. Both were fitted about two or three months ago when I installed the UK headlights.
I had a simiilar problem on a motorbike once and it turned out to be the silicon rectifier (iirc, does that sound right?) had blown. Is there something like that on our cars?
Thanks
Its a tricky one with them both going together. If they are protected by properly rated fuses then you'd think a power spike/surge would blow the fuses - as thats what they're for isn't it?? what is the ampage on your new bulbs??
maybe one of the bulbs was weak and blew - and the increased current going to the other one (I often see cars with one light out showing a brighter than 'normal' remaining headlight) sent the other one on its way??? Just a suggestion, hope you get to the bottom of it mate.
AMEN
Thanks Chris. I'll check the battery voltage tomorrow.
Is the alternator regulator something inside the alternator or something that can be replaced seperately?
By the way, both bulbs had blown when I checked today.
Just for info fuses will take about 4 times their rating for a brief moment (dependent on the ambient temp) and the amount of extra current so your 15 amp fuses could pass 45 amps for a very short time -enough to take out your headlights as chris said , the voltage reg in the alternator could be playing up or the brushes in the alt sparking/worn out causing the volts reg to throw a wobblie,most alts have a surge diode in them to prevent more than 18 volts( I dont know if the supe has one)
The thing is you may check the o/p volts and its fine,until it spikes again -yet another set of headlight bulbs if they are switched on whilst the volts spike( headlights are more susceptable to blowing cos they are one of the hottest and heaviest loads on the car)-- then again it could just be cheap bulbs :D -- I know a recon alt replacement may be a pain /expense , but so is new bulbs,and fried battery
