kslb Posted July 27, 2007 Share Posted July 27, 2007 I have done a search but cannot find the info I am looking for. My petrol gauge is not working, it is showing empty all the time and no movement on start up or anything. Any advice would be helpfull as I need to get it sorted. It has recently had an AEM fitted and twin fuel pumps I hope this helps. Thanks. Keith. Link to comment Share on other sites More sharing options...
kieren1234 Posted July 27, 2007 Share Posted July 27, 2007 All fuses checked???? Did you disconnect the battery when fitting the fuel pumps as this may have blown it. Link to comment Share on other sites More sharing options...
kslb Posted July 27, 2007 Author Share Posted July 27, 2007 All fuses checked???? Did you disconnect the battery when fitting the fuel pumps as this may have blown it. I have checked the fuses and they all seem ok but didn't find one that said fuel guage have checked the ones under the bonnet and drivers foot well is there any others fuel related? Link to comment Share on other sites More sharing options...
SimonB Posted July 27, 2007 Share Posted July 27, 2007 Sounds like the sensor is not plugged in, or has fallen off or something inside the tank if you've just fitted twin pumps in there. Link to comment Share on other sites More sharing options...
supradibbs Posted July 27, 2007 Share Posted July 27, 2007 does the gauge move wilst driving if it does prob the level sensor come uncliped in the tank mine seems to work from full to 3/4 tank then stops work????? oh on a diffrent note ask your missus to put done her name on the mat group by if she still wants a set Link to comment Share on other sites More sharing options...
kslb Posted July 28, 2007 Author Share Posted July 28, 2007 does the gauge move wilst driving if it does prob the level sensor come uncliped in the tank mine seems to work from full to 3/4 tank then stops work????? oh on a diffrent note ask your missus to put done her name on the mat group by if she still wants a set It doesn't move at all but it goes to the garage on tuesday to get a few bits sorted. Will tell Eve and I will put my name down too. Cheers Keith Link to comment Share on other sites More sharing options...
kslb Posted July 28, 2007 Author Share Posted July 28, 2007 Sounds like the sensor is not plugged in, or has fallen off or something inside the tank if you've just fitted twin pumps in there. Cheers will give it a try. Link to comment Share on other sites More sharing options...
