Master Cylinder
mitchell
I have been doing the same over the past couple of weeks mate. I tried using the overhaul kit from toyota (£92) but this didnt work out so I have ordered a second hand one. There are a few different ones depending on the model. If your n/a has abs it should have two brake line outputs which I am fairly sure is the same as the tt ( I think they all have abs). If your n/a does'nt have abs then you will need the cylinder with three brake line outpus. I will put up some pics when I am at home to show you a non abs one.
Dave
