Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 Because I am anal, I want to Datalog a VVTi's stock timing map. The JDM OBD2 uses a different protocol than European, so a normal OBD2 scanner cant read it. Sooooo, I am looking for something that I can wire from the crank trigger output to log the timing. Any ideas guys?? Quote Link to comment Share on other sites More sharing options...
eyefi Posted October 29, 2004 Share Posted October 29, 2004 it's a tricky one, 'cos it's not just logging a voltage. dont u need to compare the cps with the ignition signal and derive a degree value from that? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 Yes. I wondered if anyone had actually come across a box on their travels specifically for this rather than getting my head around configuring something. Now the Blitz R-Vit can do it, ( read degrees of timing) but AFAIK has no datalogging capabilities which is a real shame. If these things could datalog they would be perfect as they also read RPM, Pressure etc. Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 29, 2004 Share Posted October 29, 2004 Terry, you could use the blitz R-vit and a video camera if you were desperate, some video editing software to step through each frame and get the timing, pressure, and RPM values... -Ian Quote Link to comment Share on other sites More sharing options...
eyefi Posted October 29, 2004 Share Posted October 29, 2004 what's yr ems (piggyback) setup? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 LMAO Chis, you have too much time also not sure it displays it all at once, but a good thought The R-Vit also uses IR to the power meter. Wonder if Julian at RL can convert the signal?? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 well I really only want the inputs the stock ECU is seeing eyefi. Quote Link to comment Share on other sites More sharing options...
eyefi Posted October 29, 2004 Share Posted October 29, 2004 how much use would this data b without being timecoded to any other data thats logged at the same time? r u planning on just using the rpm as a rough timecode? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 Yes that was the plan as I can datalog pressure, AFR, TPS, AFM input via the Map ECU. If the R-Vit can be made to do it, then it becomes the hot ticket. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 The Video maybe an option. it looks like it can display 6 inputs at once Quote Link to comment Share on other sites More sharing options...
eyefi Posted October 29, 2004 Share Posted October 29, 2004 it's all a bit "heath robinson" isn't it? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 Originally posted by eyefi it's all a bit "heath robinson" isn't it? Absolutely mate Unless one of the other performance tuners has done it before, it may be the only way. Quote Link to comment Share on other sites More sharing options...
eyefi Posted October 29, 2004 Share Posted October 29, 2004 is there no jap obd2 scan tools? i would have thought there would b Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 Originally posted by eyefi is there no jap obd2 scan tools? i would have thought there would b Possible but not sure I could read it if I got one?? Quote Link to comment Share on other sites More sharing options...
matt Posted October 29, 2004 Share Posted October 29, 2004 This anygood? You'll obviously need a connector/ converter to serial....... but should be easy enough Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 Thanks Matt, I looked at something similar, but they apparently wont recognise the JDM only ones, In fact I know someone who has all the Toyota Europe readers, and they wont recognise it either. Quote Link to comment Share on other sites More sharing options...
matt Posted October 29, 2004 Share Posted October 29, 2004 Which protocol does the soop use?? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 If I knew that I would be a happy man:) The VVTi TT was never destined to be sold outside Japan, so they have their own OBD2 protocol apparently. Quote Link to comment Share on other sites More sharing options...
matt Posted October 29, 2004 Share Posted October 29, 2004 I see ...... could be tricky then! Quote Link to comment Share on other sites More sharing options...
TLicense Posted October 29, 2004 Share Posted October 29, 2004 Is there no way you could temporarily hook up some kind of piggy back that can datalog (Don't know which ones can/can't) but just leave it un-programmed? (ie +/- 0 advance from the ecu) Best of luck... Quote Link to comment Share on other sites More sharing options...
jagman Posted October 29, 2004 Share Posted October 29, 2004 it may be possible using an oscilloscope with 2 input probes and comparing the waveform shift( timing)-to datalog it unless you use a scope with memory/playback you would have to video it- try carsoft in buckingham may be able to help you- hth Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 29, 2004 Share Posted October 29, 2004 Thanks Adam Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted October 29, 2004 Share Posted October 29, 2004 Anyone want to volunteer to sit under the bonnet with a timing light? Sorry, that wasn't helpful at all... Quote Link to comment Share on other sites More sharing options...
eyefi Posted October 29, 2004 Share Posted October 29, 2004 ...writing it down right quick Quote Link to comment Share on other sites More sharing options...
dandan Posted October 30, 2004 Share Posted October 30, 2004 Didn't you guys have some software for the EManage that could log actual ignition timing values? Quote Link to comment Share on other sites More sharing options...
