Datalogging Timing
Guest Terry S
Guest Terry S
Because I am anal, I want to Datalog a VVTi's stock timing map. The JDM OBD2 uses a different protocol than European, so a normal OBD2 scanner cant read it. Sooooo, I am looking for something that I can wire from the crank trigger output to log the timing. Any ideas guys??
Guest Terry S
Yes. I wondered if anyone had actually come across a box on their travels specifically for this rather than getting my head around configuring something.
Now the Blitz R-Vit can do it, ( read degrees of timing) but AFAIK has no datalogging capabilities which is a real shame. If these things could datalog they would be perfect as they also read RPM, Pressure etc.
Guest Terry S
LMAO Chis, you have too much time ;)
also not sure it displays it all at once, but a good thought
The R-Vit also uses IR to the power meter. Wonder if Julian at RL can convert the signal??
Guest Terry S
Yes that was the plan as I can datalog pressure, AFR, TPS, AFM input via the Map ECU. If the R-Vit can be made to do it, then it becomes the hot ticket.
Guest Terry S
Originally posted by eyefi
it's all a bit "heath robinson" isn't it? :p
Absolutely mate ;)
Unless one of the other performance tuners has done it before, it may be the only way.
Guest Terry S
is there no jap obd2 scan tools? i would have thought there would b
Possible but not sure I could read it if I got one??
Guest Terry S
Thanks Matt, I looked at something similar, but they apparently wont recognise the JDM only ones, In fact I know someone who has all the Toyota Europe readers, and they wont recognise it either.
Guest Terry S
If I knew that I would be a happy man:)
The VVTi TT was never destined to be sold outside Japan, so they have their own OBD2 protocol apparently.
