Compression
Gaz6002
I've just bought a new engine and the compression is showing as 14bar on all 6 cylinders. Is this correct? I was under the impression it should be lower than 14? Closer to 12?
It should be just a stock 2JZ-GTE lump (cannot see any mods anyway).
200psi does sound a bit high for a TT.
How are you checking it?
Warm engine, Plugs out, crank until pressure builds and read.
The engine is meant to have covered just 27,000km so only just run in but still, it just seems too high. I'm racking my brain for possible causes.
The car will be mapped on the power FC as soon as prepared but I don't want to get that far along if i'm going to have to get the head off again!
Thinking about it Gaz 200psi is probably about right for a low mileage engine with stock head gasket.
My 93 RZ was around 185-190psi per cylinder and that was at 80k miles.
Really? In that case Jake thank you very much! You've put my mind at rest. I think I can live with that. I guess it shows that the engines mileage is more than likely accurate :)
