randy Posted March 24, 2002 Share Posted March 24, 2002 Hey guys I feel my clutch is kinda not releasing properly- It releases only at the end which means I have to take my foot off the clutch completely. I don't know wheather this is Ok? Cause it was releasing a lot lower when I got my car. Is there some way to adjust the clutch to release lower than releasing right at the end? I hope you understand what I mean! Also how do I know if my clutch needs replacing? (Edited by randy at 8:39 pm on Mar. 26, 2002) Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted March 24, 2002 Share Posted March 24, 2002 If it slips all the time and sometimes smells horrible, its gone At least you'll have an excuse to buy and uprated one though :biggrin: Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 24, 2002 Share Posted March 24, 2002 Have you checked the clutch fluid ? Quote Link to comment Share on other sites More sharing options...
randy Posted March 24, 2002 Author Share Posted March 24, 2002 No I have't checked the clutch fluid! Will check! But why is my clutch releasing right at the end of the pedel position? Can this be adjusted? Is this the same with your cars? Quote Link to comment Share on other sites More sharing options...
Alex Posted March 24, 2002 Share Posted March 24, 2002 The clutch is hydralic so it shouldn't need adjustment if there is enough fluid Quote Link to comment Share on other sites More sharing options...
randy Posted March 24, 2002 Author Share Posted March 24, 2002 Alex, What clutch fluid do I need to use? Brand / Grade? Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 24, 2002 Share Posted March 24, 2002 DOT 3 or 4 brake fluid should be OK. Quote Link to comment Share on other sites More sharing options...
randy Posted March 29, 2002 Author Share Posted March 29, 2002 I got my clutch checked by my mechanic and yes~ It's gone and needs to be replaced as it is releasing the power slow from start and the Revs are climbing before the power comes on. :sad: Please give me some advice thinking of buying the TRD single disc or the RPS stage-2? Do you have any recommendations? Thanks Quote Link to comment Share on other sites More sharing options...
