dangerous brain Posted October 27, 2004 Share Posted October 27, 2004 I took the dash apart the other day and since have noticed that I have a flashing O/D off light when not in gear. I have RLTC and until recently had a flashing trac light. I disconnected the trac switch which solved the flashing light issue. Was that a bad idea? I also disconnected the active spoiler switch cos that was annoying me as well. Now until recently I had a turbo timer mounted on top of the steering column and couldn't see if the O/D off light was flashing or not so I don't know if it started before or after i buggered about with the dash. If it has no effect and no other reason than the RLTC being fitted then its not that much of an annoyance to worry about. If disconnecting the trac switch has implications then someone please pipe up. Quote Link to comment Share on other sites More sharing options...
Guest Sakura Posted October 27, 2004 Share Posted October 27, 2004 You just can't stop fiddling with it, can you? Quote Link to comment Share on other sites More sharing options...
lovatt Posted October 27, 2004 Share Posted October 27, 2004 mine did this after i fitted the heater matrix, it took 3 days to sort itself out never figured out what it was there you go how much more help can i be i think its something to do with speed signal Quote Link to comment Share on other sites More sharing options...
Whitelightning Posted October 27, 2004 Share Posted October 27, 2004 The day you stop fiddling is the day you might as well pack up and die Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted October 27, 2004 Author Share Posted October 27, 2004 I wasn't fiddling I was just fitting my sattelite tracking device, which incidentally aint workin properly Works well enough to keep popping up a k-band alert on the snooper though When i took the dash and and stereo out it started a whole host of niggly bloody leccy faults that I had to try and sort out. Quote Link to comment Share on other sites More sharing options...
Dave Posted October 28, 2004 Share Posted October 28, 2004 i had exactly the same prob took off the cowling round the gear stick pulled out all the plug ins give em all a brush with a soft toothbrush plugged em all back in no more flashing o/d light that was 2 months ago hasnt flashed since- go figure Quote Link to comment Share on other sites More sharing options...
lovatt Posted October 28, 2004 Share Posted October 28, 2004 the blue plug infront of the gearstick unit is the OD plug Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted October 30, 2004 Author Share Posted October 30, 2004 will have a play with it 2moro then Quote Link to comment Share on other sites More sharing options...
