scooby_doo_do Posted October 27, 2004 Share Posted October 27, 2004 Prob a silly question and something that we all have, but just after i put the gear in first and reverse it makes a "clonk" noise from somewhere underneath... I've noticed it more since i had my new clutch put on, and some freinds of mine have also noticed it and asked what it was... I know the mkiv is suppose to be clonky but i didn't know if there was anything that can be done to fix it ? Thanks in advance as always.... Doing my gaskets tommorrow by the spark plugs weather depending ! Link to comment Share on other sites More sharing options...
fredm Posted October 27, 2004 Share Posted October 27, 2004 If the clonk occurs just as the gear lever moves into first and reverse it could be that the clutch is just dragging a bit. Try bleeding the clutch. Link to comment Share on other sites More sharing options...
green_dragon Posted October 27, 2004 Share Posted October 27, 2004 Mine does it too. I just figured it was the prop-shaft taking the strain ready for lift off... But what do I know? F-all ! Chris Link to comment Share on other sites More sharing options...
absz Posted October 27, 2004 Share Posted October 27, 2004 have you had your propshaft uj's checked for wear or loose bolts? normally clonks when you first take up drive. Link to comment Share on other sites More sharing options...
Red Posted October 27, 2004 Share Posted October 27, 2004 Mine does it too dude - I always wondered about it myself to be honest. I assumed it was somthing to do with the driveshaft going all the way down the back and something engaging along the way. I guess if it happens to a few of us it must be normal?!?!? Link to comment Share on other sites More sharing options...
SimonB Posted October 27, 2004 Share Posted October 27, 2004 Yep, me too (if you mean the clonking that you get if you come on and off the throttle in 1st going really slow). Not sure what it is, but it's normal AFAIK. Link to comment Share on other sites More sharing options...
Red Posted October 27, 2004 Share Posted October 27, 2004 I don't think he means that si, Even at idle, if you select first gear - after about half a second or so there is a 'clonk!' not when playing with the throttle. Link to comment Share on other sites More sharing options...
SimonB Posted October 27, 2004 Share Posted October 27, 2004 Originally posted by Red I don't think he means that si, Even at idle, if you select first gear - after about half a second or so there is a 'clonk!' not when playing with the throttle. Oh, in that case I don't have that! Link to comment Share on other sites More sharing options...
absz Posted October 28, 2004 Share Posted October 28, 2004 bit suprised about this clonking noise as there is no noise at all on mine? i cant see have a clonk on the transmission as being normal. Link to comment Share on other sites More sharing options...
scooby_doo_do Posted October 28, 2004 Author Share Posted October 28, 2004 Had a mechanic look at it today on a ramp and he said it was the prop-shaft wearing... He said its not really a problem as its only the initial strain when it goes into gear. He also said that it'll be worth changing so stop the noise and it wouldn't cost a lot of money - This i don't beleive... Theres not one thing on the dam car that hasn't cost a lot of money Link to comment Share on other sites More sharing options...
