Guest Chumpalot Posted July 23, 2007 Share Posted July 23, 2007 Me again, I don't like posting in this forum I passed a friend on the motorway at the weekend and when we pulled up he said as I went past him a large cloud of black smoke came out of the exhaust What could be the possible causes of this? I've also been having trouble boosting above .85bar for the past week or so and not sure if this is related? Split or loose boost hoses perhaps? Cheers Dave Quote Link to comment Share on other sites More sharing options...
mr lover Posted July 23, 2007 Share Posted July 23, 2007 black smoke is overfuelling Quote Link to comment Share on other sites More sharing options...
gaz1 Posted July 23, 2007 Share Posted July 23, 2007 Me again, I don't like posting in this forum I passed a friend on the motorway at the weekend and when we pulled up he said as I went past him a large cloud of black smoke came out of the exhaust What could be the possible causes of this? I've also been having trouble boosting above .85bar for the past week or so and not sure if this is related? Split or loose boost hoses perhaps? Cheers Dave err why don,t you like posting on this forum mate:( as mr lover says over fueling Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted July 23, 2007 Share Posted July 23, 2007 Me again, I don't like posting in this forum I passed a friend on the motorway at the weekend and when we pulled up he said as I went past him a large cloud of black smoke came out of the exhaust What could be the possible causes of this? I've also been having trouble boosting above .85bar for the past week or so and not sure if this is related? Split or loose boost hoses perhaps? Cheers Dave Are you running a stock ecu? Check your plugs for fouling.... you could be doing more damage than good. Also if you have the wrong type of atmospheric dump valve that could make you run pig rich too.. Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted July 23, 2007 Share Posted July 23, 2007 err why don,t you like posting on this forum mate:( as mr lover says over fueling In Technical i meant. Usually means i have something wrong with the car Thanks for the replies guys. Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted July 24, 2007 Share Posted July 24, 2007 Right, plugs seem to be fine. I'm running an HKS BOV. I haven't had any smoke since owning the car and it's only started doing it. I still need to check the pipes but from a quick inspection earlier there didn't seem to be any loose or cracked hoses. Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted July 24, 2007 Share Posted July 24, 2007 i've just had a thought... the current plugs on there at the moment are HKS Iridiums. I had a quick glance at the spark plug FAQ and noticed that these were simply rebranded/relablled Denso plugs and not up to the job of BPU/Hybrids. Would it be sensible to invest in some NGK plugs perhaps? If so, what ones? After the drive home tonight I'm going to check the plugs for a second time to see if anything is wrong. Cheers Dave Quote Link to comment Share on other sites More sharing options...
