Would this work ? Volt gauge...
Missile
Im deciding weather to loose my clock or cig lighter, And replace with a volt gauge...
My question is.... Will the wiring for the cig lighter or clock splice onto the wires needed to make a volt gauge work.
Plus would you loose the clock of cig lighter.
Would a gauge down as low as the cig lighter be too low.
:search::search::search:
It would provide a voltage feed, I personally wouldn't bother with a voltage gauge, however if you must, I'd place it on the ECU wires... That is the one you want to ensure gets the smoothest voltage really..... (Could be way off on this...)
