Piston slap.
Digsy
Since there was a bit of interest generated over piston slap in Dil's the cambelt change thread, here is a new one in which we can further investigate the phenomenon.
I've attached a quick sketch showing how the piston side load reverses during the power and exhaust strokes on a four-stroke engine. I'm pretty sure that piston slap has something to do with this, coupled with - as Myles said - the piston not fitting the bore properly intil it has expanded slightly.
And these sketches are my attempt to show how piston pin offset transfers the side thrust to the cylinder wall before the piston reaches TCD.
Hopefully on Monday I'll be able to tie all this together with a proper explanation! :conf:
