wallace9 Posted July 21, 2007 Share Posted July 21, 2007 I'm going to sound really stupid here but I've just recieved my clear indicators (Thanks Nic) and don't know how to fit them. Do the old ones just pull out or do I have to remove the wing? Link to comment Share on other sites More sharing options...
hiten55 Posted July 21, 2007 Share Posted July 21, 2007 do a search mate, i saw a post on here a while aback with pictures, basically you slide the towards the back of the car and they clip out. but do a search 1st - just incase Link to comment Share on other sites More sharing options...
stupra Posted July 21, 2007 Share Posted July 21, 2007 I'm going to sound really stupid here but I've just recieved my clear indicators (Thanks Nic) and don't know how to fit them. Do the old ones just pull out or do I have to remove the wing? Do you mean the small indicator's on the wing itself ?, if so, you have to pull or push them back a little, then pull them out. Link to comment Share on other sites More sharing options...
Nic Posted July 21, 2007 Share Posted July 21, 2007 They are just a push fit on, there is a sprung plastic clip on the side of the body of the side marker that holds them in place (have a look at the ones I sent you and you should see what I mean). If you push and slide the side marker to one side (can't remember which) they should just pull out. Link to comment Share on other sites More sharing options...
wallace9 Posted July 21, 2007 Author Share Posted July 21, 2007 Cheers Link to comment Share on other sites More sharing options...
brettjones Posted July 21, 2007 Share Posted July 21, 2007 They are just a push fit on, there is a sprung plastic clip on the side of the body of the side marker that holds them in place (have a look at the ones I sent you and you should see what I mean). If you push and slide the side marker to one side (can't remember which) they should just pull out. hi nic can you get these smoked Link to comment Share on other sites More sharing options...
Pot Posted July 21, 2007 Share Posted July 21, 2007 Exactly as has been posted, it might need a hard(ish) push, but only as the rubber behind will have stuck, I did mine and it was easy Link to comment Share on other sites More sharing options...
chilly Posted July 21, 2007 Share Posted July 21, 2007 Exactly as has been posted, it might need a hard(ish) push, but only as the rubber behind will have stuck, I did mine and it was easy Hows you car coming on fella? Its been a while since your smash, you nearly there yet? Link to comment Share on other sites More sharing options...
