Tricky-Ricky Posted July 20, 2007 Share Posted July 20, 2007 Has anyone ever been able to access the std ECU and download the maps? or anyone seen any info anywhere? very interested in part, and opening throttle enrichment, also ignition advance. Quote Link to comment Share on other sites More sharing options...
bondango Posted July 22, 2007 Share Posted July 22, 2007 The only person i know is Reg Reimer of RCTS canada, they use the Techtom. Apparently he's a bit more "open" on the phone (403) 259-3106 We tried logging the Stock ignition Timing using the Innovate auxbox with a VR sensor mounted on the crank as per Innovates methods but it was pants and give false readings, couldnt get any help from them on the issue either. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 22, 2007 Author Share Posted July 22, 2007 Been searching but found nothing, i had no problem with the S14 maps but Supra seems non existent, just a thought, have anyone got a Power FC Supra TT base map? at least that would give me an idea, i know that its going to be rich as f##k and the timing is going to be conservative but it would give me an insight into the STD map settings. Quote Link to comment Share on other sites More sharing options...
bondango Posted August 3, 2007 Share Posted August 3, 2007 Tricky have found the Timing MAP, believe it to be USDM2jz-gte_timing_map.xls Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 3, 2007 Author Share Posted August 3, 2007 Thanks a lot mate:) that should help a lot. Quote Link to comment Share on other sites More sharing options...
Alex Posted August 3, 2007 Share Posted August 3, 2007 Anyone know what the load points are? Quote Link to comment Share on other sites More sharing options...
dandan Posted August 3, 2007 Share Posted August 3, 2007 Probably something like 0-220kpa (absolute) or 1bar vac to 1.2bar boost with a load point every 10kPa or 1.45psi. I don't recall what the stock map sensor reads to so am half guessing.... Quote Link to comment Share on other sites More sharing options...
bondango Posted August 3, 2007 Share Posted August 3, 2007 As they are USDM Timing maps, you'll need this.. http://mkiv.com/tmp/maf_voltage_vs_lb_min/maf_voltage_vs_lb_min.xls Quote Link to comment Share on other sites More sharing options...
dandan Posted August 3, 2007 Share Posted August 3, 2007 Oh yeah they're bloody MAF aren't they....shame. Quote Link to comment Share on other sites More sharing options...
