Justin Posted May 26, 2002 Share Posted May 26, 2002 FAO Electricians etc After successfully removing my active spoiler I now have the large red warning triangle in my speedo permanently. I guess it is being triggered by the loss of continuity to the assembly no? I thought just by unplugging the switch in the dash would stop it but it is a bit cleverer than me obviously. Questions: 1. Do I need to make a bridge to cause a circuit between two pins/wires in the remaining male half of the connector. Does anyone know what colours I should connect up if this is the case. There are 5 pins in the connector. (see pic) or 2. Do I just locate and pull out an appropriate fuse? Any other good ideas welcome Cheers Quote Link to comment Share on other sites More sharing options...
Alex Posted May 26, 2002 Share Posted May 26, 2002 Hi ya, To disable my active spoiler I unplugged it from behind the stereo. There is a silver box behind the stereo ontop of or below the ABS unit unplug it and it disables the active spoiler with no dashboard warning lights. I think its the silver ox with the smaller connector in it, the other silver box has a very wide plug on it. I just guessed when I did it....not the most scientific experiment ever!!! Quote Link to comment Share on other sites More sharing options...
Justin Posted May 26, 2002 Author Share Posted May 26, 2002 Cheers Alex Quote Link to comment Share on other sites More sharing options...
THOR Racing Posted May 27, 2002 Share Posted May 27, 2002 Just short pins 3&4 of the connector. This makes the Spoiler unit believe the blade is parked. Pete Quote Link to comment Share on other sites More sharing options...
