Elliot Posted October 25, 2004 Share Posted October 25, 2004 Hola At the moment I have Falken tyres all round. The 2 rear tyres are almost bald so need to replace them ASAP. Is it advisable to put some Eagle F1s, or Bridgestone SO3s on the rear with Falken fronts, or should I stick to Falken all round? Basicly, is it OK to mix and match them? Also, does anyone in HAMPSHIRE have any recommendations for tyre fitting / laser allignment? At the moment, I have the number for Micheldever in Winchester are they any good, or is there somewhere cheaper or better in the area? BTW - I'm looking for 275/35/zr18 Thanks for helping Link to comment Share on other sites More sharing options...
merckx Posted October 25, 2004 Share Posted October 25, 2004 It is okay to put different tyres on the back or front. It's best not to mix tyres on the same axle though. Link to comment Share on other sites More sharing options...
SkyJawa Posted October 25, 2004 Share Posted October 25, 2004 Micheldever are fine! You can mix front to rear, but not on the same axle. Putting F1's on the rear will mean the rears will probably grip a bit better than the fronts, so perhaps a little understeer. If they are Falken F451, then they aren't too bad so it shouldn't be that noticable.......... Link to comment Share on other sites More sharing options...
Thorin Posted October 26, 2004 Share Posted October 26, 2004 Falken 451's are a fine tyre, I had those up front and F1's at the back and were fine. However I recently had a rear puncture and had a cheapo "Kleber" tyre fitted on one side at the rear. Terrible. It's supprising how much of a difference it makes, car does not feel stable at high speeds (not that I've done that high a speed as I don't trust the crappy tyre), and the car wanders a lot more. Needless to say I'm getting both rears replaced with new F1's. Link to comment Share on other sites More sharing options...
Elliot Posted October 26, 2004 Author Share Posted October 26, 2004 When I phoned them they recommended the same make all round, as I was going to get F1's or SO3's on the back. My front tyres are Falken and pretty new so I went with the Falkens at the rear at around £120 each. Link to comment Share on other sites More sharing options...
merckx Posted October 26, 2004 Share Posted October 26, 2004 When I phoned them they recommended the same make all round, as I was going to get F1's or SO3's on the back. What a load of bollocks! No need to have the same tyres all round, the levels of grip from the front to rear are going to vary anyhow because of the balance of the car and in your case the rear tyres are wider than the front. Link to comment Share on other sites More sharing options...
Elliot Posted October 26, 2004 Author Share Posted October 26, 2004 Haha! Just what he said I'm afraid! Maybe they get a better profit on the Falkens then, as the prices of the other tyres were a lot more. Link to comment Share on other sites More sharing options...
Trig Posted October 26, 2004 Share Posted October 26, 2004 i have Falkens all round. A worthy tyre IMO Link to comment Share on other sites More sharing options...
Syed Shah Posted October 26, 2004 Share Posted October 26, 2004 Not ideal, but different tires front and rear are fine. Falkens are crap IMHO. Get the F1s or S0-3s, both great tires. Then again, that depends on how you drive. Link to comment Share on other sites More sharing options...
Bobbeh Posted October 26, 2004 Share Posted October 26, 2004 Originally posted by merckx What a load of bollocks! They only say that cos they're trying to get you to buy more. Same tyre per axle. Link to comment Share on other sites More sharing options...
michael Posted October 26, 2004 Share Posted October 26, 2004 No matter which tyre you buy there is always going to be a better option for more money - over the past 5 years I've used F1's, S03's, P9000's, ZE502's, FK451's and others - the Falkens aren't bad at all, especially considering the price - my car grips well in the dry and breaks traction in the wet, that's a power issue Link to comment Share on other sites More sharing options...
SkyJawa Posted October 26, 2004 Share Posted October 26, 2004 I've used a lot of tyres in my time and the Falkens are not bad. However for me, the F1's were only a tenner more each, so it was a no brainer! Link to comment Share on other sites More sharing options...
