paul_y3k Posted July 17, 2007 Share Posted July 17, 2007 Originally a Black TT Aerotop Supra imported 3 years ago, and after a bown turbo I decided to go single turbo. Car specs are now : Greddy 3 Row FMIC Greddy Top Hose with Temp probe fitted Sound Performance Manifold Sound Performance T61 Turbo Blitz 650CC injectors Trail Wastegate HKS SSQV Blow Off Valve HKS 2mm 'Stopper type' MHG ARP Head Bolt Kit Sound Performance Induction Kit Fluidyne Dual Core Radiator Flexalite Electric Fans Envy Transmission fluid Cooler Tien Type HA Coilovers 18" Advan Super Alloys KAD 6pot front callipers TRD pads RSR Exhaust Full decatt Hosetechniques Hose Set Profec E-O1 Boost controller Emanage ECU Race Logic traction Control Fields Harness Full rebuilt engine Plus lots of toyota belts and bits too Car Pics : And the original dyno chart Now for the bad bits. The heater matrix failed and gave the ECU's a bath. At this point the car was mis firing and went to Interpro who checked it out. The engine was fine, but the ECU's were contaminated so were all cleaned out, which cured the misfiring. During that time a compression was performed on the engine and it was fine. I drove it home and for a couple of weeks all ok. I then went on holiday, and returned to find that the car was running very rough again. I checked the plugs and they were ok and I suspect that the issue is the ECU's have sweated in the heat and become contaminated again. To this end i have bought some replacment ECU's which need to be fitted, and then I suspect the car will need a mapping session. So at this point all though the engine does start i do not view the car as drivable. To add that little bit more, I painted the calibers the otehr day, but the car moved on the jack (8am wasn't truly awake) and I now have a small hole in the passenger footwell regards paul Link to comment Share on other sites More sharing options...
paul_y3k Posted July 18, 2007 Author Share Posted July 18, 2007 am I asking to much ? I have said OFFERS ? Link to comment Share on other sites More sharing options...
wkdtime Posted July 18, 2007 Share Posted July 18, 2007 Price look's spot on there bud, give it time. Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 18, 2007 Share Posted July 18, 2007 looks like a bargain mate, hold out. Link to comment Share on other sites More sharing options...
GeordieSteve Posted July 18, 2007 Share Posted July 18, 2007 Yeah seems quite cheap to me Link to comment Share on other sites More sharing options...
paul_y3k Posted August 2, 2007 Author Share Posted August 2, 2007 bump. also the electric are most likely to need replacing as it does seem to be running rough. Also have just discovered the cam pullys were not replaced and so likely the same with the cams themselves. therefore open to any sensible offers. Link to comment Share on other sites More sharing options...
paul_y3k Posted August 24, 2007 Author Share Posted August 24, 2007 bump and update, I've now got a replacement EManage unit which will be included in sale. So this just need the time to plug it all in, map and away you go. and just to re iterate, I'm open to offers ! Link to comment Share on other sites More sharing options...
wallace9 Posted August 24, 2007 Share Posted August 24, 2007 Man that looks nice. I'll swap you for my N/A Link to comment Share on other sites More sharing options...
paul_y3k Posted August 24, 2007 Author Share Posted August 24, 2007 err tempting, but I need cold hard cash ! Link to comment Share on other sites More sharing options...
wallace9 Posted August 24, 2007 Share Posted August 24, 2007 Well I could give you cold hard cash.....Just not very much Good luck with the sale. Link to comment Share on other sites More sharing options...
paul_y3k Posted August 24, 2007 Author Share Posted August 24, 2007 well Im always open to offers Link to comment Share on other sites More sharing options...
wallace9 Posted August 24, 2007 Share Posted August 24, 2007 When I said not a lot I'm afraid I meant not a lot. It would only be the money I got from selling my NA as all my cash at the moment is going into a wedding and a house deposit. How long has the car been for sale for? I wouldn't have thought a car with that spec that looks in such good condition would be a problem to sell. Link to comment Share on other sites More sharing options...
