Missile Posted July 17, 2007 Share Posted July 17, 2007 Are the jap import pads the same on the turbo as the NA ? Just called my local parts place to get a quote on some front pads as hoping to get all four changed asap, But they say the import pads are all the same. Anyone able to comfirm this is right or wrong. Don't wanna order the wrong things. I've done a search, Was lots there but not anything that could clarify this question. Link to comment Share on other sites More sharing options...
JODY T Posted July 17, 2007 Share Posted July 17, 2007 They did 2 types of caliper jspec and UK spec.. Uks being larger.. The front and rears are different, as in shaped differently.. The Ukspec calipers were an option on the jspec cars though... What have you got? Are the jap import pads the same on the turbo as the NA ? Just called my local parts place to get a quote on some front pads as hoping to get all four changed asap, But they say the import pads are all the same. Anyone able to comfirm this is right or wrong. Don't wanna order the wrong things. I've done a search, Was lots there but not anything that could clarify this question. Link to comment Share on other sites More sharing options...
Missile Posted July 17, 2007 Author Share Posted July 17, 2007 So all jspec ones are going to be the same, Regardless if they are TT or NA..... Link to comment Share on other sites More sharing options...
Konrad Posted July 17, 2007 Share Posted July 17, 2007 So all jspec ones are going to be the same, Regardless if they are TT or NA..... yes Link to comment Share on other sites More sharing options...
Jake Posted July 17, 2007 Share Posted July 17, 2007 So all jspec ones are going to be the same, Regardless if they are TT or NA..... It depends what you mean by "all jspec ones". Jspec Supras could have either type of brakes fitted (j-spec brakes or Uk Spec ones) But j-spec brakes on a j-spec TT are the same as j-spec brakes on a NA. Does that make it any clearer? Link to comment Share on other sites More sharing options...
Missile Posted July 17, 2007 Author Share Posted July 17, 2007 It depends what you mean by "all jspec ones". Jspec Supras could have either type of brakes fitted (j-spec brakes or Uk Spec ones) But j-spec brakes on a j-spec TT are the same as j-spec brakes on a NA. Does that make it any clearer? Clear as a bell. What i should have said, was do all j spec calipers, (Turbo or NA) Take the same pads. Thanks everyone. Link to comment Share on other sites More sharing options...
