Pig Posted July 15, 2007 Share Posted July 15, 2007 Picked the car up yesterday from a checkover (all will be revealed very soon) Now, when i boost up, at about 5K it goes completly lean (right round on the AFR gauge) Still only peak boosting @ 1.3 bar If it helps at all, when we started the car, it idled at abour 4K for some reason. It didnt drop so after 30 secs we turned the car off. It was fine as soon as we started it again. Spec - T61 - stage 3 fuel system - AEM Any ideas? Quote Link to comment Share on other sites More sharing options...
tDR Posted July 15, 2007 Share Posted July 15, 2007 Who mapped it? I would suggest a vacuum leak around the FPR so check all the hoses around there. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
b_have Posted July 15, 2007 Share Posted July 15, 2007 Do NOT drive that car on boost! I'm suprised its survived at 5000rpm/1.3bar at more than 12afr let alone off the scale. Quote Link to comment Share on other sites More sharing options...
Pig Posted July 15, 2007 Author Share Posted July 15, 2007 Who mapped it? I would suggest a vacuum leak around the FPR so check all the hoses around there. Cheers, Brian. Mapped by Dan, was fine until now though ??? Will check all hoses this morning and see if that helps Quote Link to comment Share on other sites More sharing options...
tDR Posted July 15, 2007 Share Posted July 15, 2007 Mapped by Dan... There's your problem then!!! Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 15, 2007 Share Posted July 15, 2007 if people have had problems with this guy surely you shouldnt of got it mapped by him? id say take it back and kindly ask him to sort the problem Quote Link to comment Share on other sites More sharing options...
Pig Posted July 15, 2007 Author Share Posted July 15, 2007 Do NOT drive that car on boost! I'm suprised its survived at 5000rpm/1.3bar at more than 12afr let alone off the scale. I drove at WOT 2 or 3 times before realising what the prob was. #noticed it wasnt running right, boosted up to check boost pressure (it was fine) then check fuel. I dread to think what the pistons look like now There's your problem then!!! It was running fine though, how can it just change over night? Quote Link to comment Share on other sites More sharing options...
b_have Posted July 15, 2007 Share Posted July 15, 2007 There's your problem then!!! Doubt its a mapping problem. Something has failed. Most likely a vac signal issue. Quote Link to comment Share on other sites More sharing options...
Pig Posted July 15, 2007 Author Share Posted July 15, 2007 if people have had problems with this guy surely you shouldnt of got it mapped by him? id say take it back and kindly ask him to sort the problem Its not that easy, firstly the car needs SHED loads of work to be put right and secondly no one is open on a sunday and i work all week. Therefore no time to get anything sorted. Quote Link to comment Share on other sites More sharing options...
Pig Posted July 15, 2007 Author Share Posted July 15, 2007 Most likely a vac signal issue. Thats exactly what i was thinking........ whats that?? Quote Link to comment Share on other sites More sharing options...
tDR Posted July 15, 2007 Share Posted July 15, 2007 I know Charlie, was just being obtuse! Like I've mentioned - check all of your vac hoses especially around the FPR. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted July 15, 2007 Share Posted July 15, 2007 moved to technical. sorry cant be anymore help then that Quote Link to comment Share on other sites More sharing options...
gaz1 Posted July 15, 2007 Share Posted July 15, 2007 mate i know how you feel my is running like bag of bollocks right now, i am having all the turbo pipes re done, and a remap, plus other bits and piece,s, i feel for you as its just such a pain not being right, after what we have spent it should be spot on, if its not right this time, i am going to be pissed:( Quote Link to comment Share on other sites More sharing options...
Dragonball Posted July 15, 2007 Share Posted July 15, 2007 mate i know how you feel my is running like bag of bollocks right now, i am having all the turbo pipes re done, and a remap, plus other bits and piece,s, i feel for you as its just such a pain not being right, after what we have spent it should be spot on, if its not right this time, i am going to be pissed:( Jeez Gaz - did you shake hands with Sheefa? John - dont drive the car mate! Quote Link to comment Share on other sites More sharing options...
gaz1 Posted July 15, 2007 Share Posted July 15, 2007 Jeez Gaz - did you shake hands with Sheefa? John - dont drive the car mate! no just picked the wrong traders:rolleyes: Quote Link to comment Share on other sites More sharing options...
Pig Posted July 15, 2007 Author Share Posted July 15, 2007 John - dont drive the car mate! The annoying thing is i only bought the car back so i could take it to JAE and now..... you right i shouldnt drive the car. We both no what im like so if it aint right, im not taking it. Drangon ball at 3k JAE in a smart car. Quote Link to comment Share on other sites More sharing options...
Steve Posted July 15, 2007 Share Posted July 15, 2007 Did you have a look at the vac hoses Jon? There could be a split one somewhere. Quote Link to comment Share on other sites More sharing options...
Pig Posted July 15, 2007 Author Share Posted July 15, 2007 Did you have a look at the vac hoses Jon? There could be a split one somewhere. About to get dressed and have a look. There shouldnt be though, they are all new AFAIK. Quote Link to comment Share on other sites More sharing options...
Pete Posted July 15, 2007 Share Posted July 15, 2007 no just picked the wrong traders:rolleyes: Who did yours Gaz? Quote Link to comment Share on other sites More sharing options...
Pig Posted July 15, 2007 Author Share Posted July 15, 2007 Who did yours Gaz? Turbofit Quote Link to comment Share on other sites More sharing options...
Pete Posted July 15, 2007 Share Posted July 15, 2007 Turbofit Ah....Am I beginning to spot a pattern emerging? Quote Link to comment Share on other sites More sharing options...
Steve Posted July 15, 2007 Share Posted July 15, 2007 About to get dressed and have a look. There shouldnt be though, they are all new AFAIK. Are they silicon ones? Could have got hot and expanded, then just popped off. Quote Link to comment Share on other sites More sharing options...
gaz1 Posted July 15, 2007 Share Posted July 15, 2007 Turbofit john seriously, check them, as some of mine actualy melted as they were cheap and nast one,s, one part of mine had melted and i could only just see it, my advice, get all the hoses swapped for decent high temp ones, as thats what mines getting;) Quote Link to comment Share on other sites More sharing options...
Pig Posted July 15, 2007 Author Share Posted July 15, 2007 Ah....Am I beginning to spot a pattern emerging? Just wait till this afternoon - keep an eye on the dispute section. Quote Link to comment Share on other sites More sharing options...
b_have Posted July 15, 2007 Share Posted July 15, 2007 Whatever hoses they are (oem are best) Zip tie every one. Quote Link to comment Share on other sites More sharing options...
