RobSheffield Posted July 14, 2007 Share Posted July 14, 2007 Do i need to lubricate the o-rings at all to prevent them from pinching and/or tearing? I have seen advice to cut the PHR mounting lugs down slightly, is this wise and if so, by how much?! Link to comment Share on other sites More sharing options...
SimonB Posted July 15, 2007 Share Posted July 15, 2007 Just use a bit of petrol on the o-rings to help them go in. Not sure what you mean about the mounting lugs. Do you mean the brackets that hold the rail on? Link to comment Share on other sites More sharing options...
TLicense Posted July 15, 2007 Share Posted July 15, 2007 As Simon said. I didn't cut down the mounting lugs on mine. However initially I put an O'ring on the injector collet, then following Dimtri's advice I got the collets welded to the inlet runner. Link to comment Share on other sites More sharing options...
bolarbag Posted July 16, 2007 Share Posted July 16, 2007 I didn't cut down the mounting lugs on mine. However initially I put an O'ring on the injector collet, then following Dimtri's advice I got the collets welded to the inlet runner. You got any pics please? Link to comment Share on other sites More sharing options...
michel lane Posted July 17, 2007 Share Posted July 17, 2007 SPIT on the "O" rings , acts as good lubrication, So the wife tells me .... if you havent got a welder , then just use RTV silicon sealent for the collers. Link to comment Share on other sites More sharing options...
