AEM ECU ideal for NA-T includes AIT and 3.5 bar MAP sensor
sdavies
***SOLD***
^As above, brand new unused & boxed with all bits AEM ECU, 3.5bar MAP and AIT sensors. Previously no interest, re-listing. I was sure there were a few guys thinking of going NA-T (this is what this setup was originally for) - c'mon this is a "cutting me own throat" kind of deal here.
Cheers,
Simon.
I'm SOOO interested, but need to sort a few other things out before I can even consider this item yet..
The rate the interest and enquiries are flowing in... I may have sold this by 2018... so get yer skates on ;)
No doubt I will still be using this as a paper weight when you need one Amigo :D
self inflicted bumperoonie!
stock ecu as far as i know, had the conversion done last june at tf
Oh my, oh my... But surely stock ecu wouldn't handle NA-T? Well, I would check wht's your ecu now, if it is stock then erm... I wouldn't drive this car anywhere without some piggytail ecu at least.
As mentioned, it all depends on what ECU / piggyback system you are currently using as to what gains can be offered here. I should imagine you have something other than a stock NA ecu under the hood (I bloody well hope so anyway).
The AEM EMS is an extremely configurable plug and play engine management system (well plug and play in as much as it just fits into the OEM factory loom with no hair raising splicing of wires). Feature list as long as your arm. In the hands of a capable tuner you will reap many rewards from this system. A few guys on here run AEM's and do all sorts of imaginative things with them. Bolting on extras afterwards isn't such a chore, as it has facilities for just about any gadget you may want to put on your car - well as I say - huge feature list. That being said, there are many other options out there that could give you the same basic power/tuning benefits, it all depends on where you want to go with it and if you can source a decent AEM mapper.
Cheers,
Simon.
Edit: Thought I would add the standard blurb that AEM say about the unit:
Plug & Play Engine Management Systems
AEM's Plug & Play Engine Management System (EMS) plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (2000, XP, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. An integrated tuning wizard allows users to create a base map specifically for a car’s configuration, regardless of what type of injectors, sensors, coils or other changes have been made. The AEM EMS's infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
yes its got a piggy back, injectors are standard,do you take paypal
Yes indeed Amigo, I can take PayPal, bank transfer also Queens head folding gift tokens accepted ;). If you want we can take to PM's to discuss? I can post (I'll only post it special delivery - or another insured courier method if you prefer - as that is as near a guarantee of you getting it as soon as possible with suitable insurance on it) or you can pick up, both are acceptable, I don't mind either.
