garetheves Posted July 12, 2007 Share Posted July 12, 2007 Need to change my door handles this weekend, i understand it isnt the hardest of jobs and therefore the chance of me fu*king it up like i usually do is slim. To help make sure i dont though, are there any How To guides out there or can someone who has done it before at least post up how to. Cheers Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 12, 2007 Share Posted July 12, 2007 its easy mate just some screws but you have to remove the door cards Quote Link to comment Share on other sites More sharing options...
paul mac Posted July 12, 2007 Share Posted July 12, 2007 gaz tape some cloth round the handle on the door you run the risk of scratching the paint when taking all the fiddly cental locking linkages off Quote Link to comment Share on other sites More sharing options...
garetheves Posted July 12, 2007 Author Share Posted July 12, 2007 its easy mate just some screws but you have to remove the door cards gaz tape some cloth round the handle on the door you run the risk of scratching the paint when taking all the fiddly cental locking linkages off Cheers guys. How easy are the door cards to take off without damaging them and where are the bolts/screws for them located?? Quote Link to comment Share on other sites More sharing options...
Homer Posted July 12, 2007 Share Posted July 12, 2007 Cheers guys. How easy are the door cards to take off without damaging them and where are the bolts/screws for them located?? It's very easy mate. From memory, there are two plastic clips on the side slam panel (push the centres bit in to remove). There's 3 or 4 screws underneath the door card which just undo. Then there's a couple of screws (have plastic caps) and another of those push-in plastic clips at the front of the door. Next, look down into the handle area and remove the platic cap in there and undo the bolt. There is also one screw behind the handle which just needs undoing so you can remove the plastic surround on the door handle That should be enough to get the card off the door, it should lift up and out. There is also a plug to remove for the door speaker. 5 minutes job Quote Link to comment Share on other sites More sharing options...
garetheves Posted July 12, 2007 Author Share Posted July 12, 2007 It's very easy mate. From memory, there are two plastic clips on the side slam panel (push the centres bit in to remove). There's 3 or 4 screws underneath the door card which just undo. Then there's a couple of screws (have plastic caps) and another of those push-in plastic clips at the front of the door. Next, look down into the handle area and remove the platic cap in there and undo the bolt. There is also one screw behind the handle which just needs undoing so you can remove the plastic surround on the door handle That should be enough to get the card off the door, it should lift up and out. There is also a plug to remove for the door speaker. 5 minutes job Cheers fella Thats my job for saturday morning then. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 13, 2007 Share Posted July 13, 2007 Gaz, do you want to meet up somewhere to exchange these lights? I could also give you a hand with this if you like. Ive taken the door cards off countless times for speakers? Mike Quote Link to comment Share on other sites More sharing options...
colsoop Posted July 13, 2007 Share Posted July 13, 2007 Cheers guys. How easy are the door cards to take off without damaging them and where are the bolts/screws for them located?? Gaz see here mate: Door card removal Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 13, 2007 Share Posted July 13, 2007 Gaz see here mate: Door card removal thats what i was searching for, very usefull Quote Link to comment Share on other sites More sharing options...
jazz1 Posted July 13, 2007 Share Posted July 13, 2007 edit: double post Quote Link to comment Share on other sites More sharing options...
garetheves Posted July 13, 2007 Author Share Posted July 13, 2007 Gaz, do you want to meet up somewhere to exchange these lights? I could also give you a hand with this if you like. Ive taken the door cards off countless times for speakers? Mike Cheers for the offer mate but will be doing it in Preston which is a bit of trek for you. That guide looks good so should manage no probs. Should be able to meet up sat evening or night sometime for the lights though if you want. Quote Link to comment Share on other sites More sharing options...
garetheves Posted July 13, 2007 Author Share Posted July 13, 2007 Gaz see here mate: Door card removal Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted July 13, 2007 Share Posted July 13, 2007 Cheers for the offer mate but will be doing it in Preston which is a bit of trek for you. That guide looks good so should manage no probs. Should be able to meet up sat evening or night sometime for the lights though if you want. yep no probs, just let us know where is good for you! You could always change your mind, come to JAE and bring them with you lol. Mike Quote Link to comment Share on other sites More sharing options...
turbonut Posted July 13, 2007 Share Posted July 13, 2007 Hi Gaz Probably a bit late in the day but if your changing them as they've gone pink you may not need to after all. I used Meguires ScratchX at the weekend, (mines RED too plenty of elbow grease and several applications followed by gold class polish but they've come up cherry red and gleaming, taken out the fine scratches too. Worked a treat on my jspec lights as well. Maybe give it a try first?? Good luck anyway fellah lol Lx Quote Link to comment Share on other sites More sharing options...
