Quick Response Required...
suprafan72
What are the advantages?
normal bolt type's have to streatch and therefore arent as accurate but with studs you take away the streatch factor and you get a far more accurate torque and they stay at that torque
good for high revving engines
if you were me, and i had perfect looking stock bolts, would you spend 130.00 on a new set when theres nothing wrong with the stock ones?
Im sticking to Stock RPM at the moment
it all depends on what youre plans are with the engine
if you intend to stay around the "stock" power then no i wouldent use them but if you intend building a monster then yes fit them
You cannot re-use stock head bolts - they are a stretch design and should be replaced should you need to seperate the head from the block.
Cheers,
Brian.
Thanks Brian, For 130.00 ill take the chance and order a set of ARP's then its done!
