Toyota Wiper Blades
Sharpie
The rain is here for winter so, I bought a new set of wiper blades from Toyota today. 3 new blades £15.06 all-in with dicount :)
Part numbers:
T85214-22360 £4.75 - LH6 wiper rubber
T85214-33050 £5.64 - LH5 wiper rubber
T85214-30260 £4.68 - LH3 wiper rubber
Still, normal price is under £20 :)
:eek: wiper arms are like £60 odd :eek:
Has anyone ever seen a 'How to fit your wiper blades' document ?
OK, the parts guy offered to show me ...and did fit them but, just wondered if anyone had documented this.
There is a set way of doing it.
It's cheaper going stock than anything you get at halfrauds etc....
On the stock wipers you have two maybe three parts to it.
You have the disposable wiper rubber blade, the wiper arm's that the rubber blades fit too and then the arm that is connected to the car.
The two arms above could be sold as one unit, I did not question the parts guy but, I assume that the metal parts (two arms) he was referring too at the £60 mark.
The prices above are just the disposable wiper rubber blades.
A good idea from Toyota IMO
HTH
Originally posted by Paul -C-
I had to buy wiper blades with a spoiler on them from Halfrauds. The previous ones on the car (dunno if they were stock) were useless at speed, just missed the full window when wiping.
The stock arms have a spoiler on the drivers side but not passenger for some reason.
they seem pretty good upto 140ish but they do sqeak a bit, not that i'd do 140 in the rain, well not unless i was chasing millhouse cj and simonB :D
The last rubbers i got were a fiver each all in
I bought a complete new set a couple of weeks ago for 60quid.
Bloody expensive but I thought about buying just the rubbers but remembered trying to change them on my first car and it was more hassle than it was worth..
The Halfrauds one's are sh*te.
Originally posted by merckx
You are joking, aren't you? :eek:
It's pretty obvious how to fit them.:D
No, I’m not taking the pi$$ - If you are used to having the wipers changed during a service before winter OR have purchased Bosch wiper blades for previous cars then it’s just a clip on arm so, a no brainer.
So, when I come to change the arms at a non service time and get given three rubber strips of different lengths, then I was curious how they were fitted since, I have not seen anything on here or elsewhere before detailing the process and what to watch out for ‘scratching your paint’ etc…
Yes, it’s a 10min job once you have done it for the first time but, I did not know about the below:
· Making sure that the rubber buldge at one end of the blade is kept at the same end on the arm when fitting the new one.
· The metal strips with the cut outs which run along the blades are reused and are put back on with the cut outs facing inwards
· You might need to gently adjust the claws that hold the rubber blade in place with a pair of pliers if needed should, the new blades don’t go on after the 8th time of trying.
· Making sure that you open/extend the wiper blade out away from the car before pulling the old rubber blade out as if you slip the metal strips in the rubber blade can scratch your paintwork.
Why pay £40-60 when you can pay £15-20 as the arms do not need changing as often as the blades.
I thought the above info or a HOW TOO document would be useful to noobs OR people who have never done this before – Don’t you agree ?
I’m sure you will agree that there are various levels of technical abilities on here so, any useful info about a subject is always welcome.
Fair enough!:)
As you say, there are various levels of technical abilities on here.
I can think of a few people in my family that would need some guidance too.
Wiper blades.... Smiper blades..... Who needs em. I find a nice couple of coats of RainX on the windscreen works a treat!
At 140 the rains got no chance of staying on there!!!!!
:p
Having said that my wiperblades are shot, i don't recall having a spoiler on the drivers one does this mean there mickey mouse jobbies?
Are Halfruad ones really that bad, i kinda fancied some nice new complete blades and my wiper arms look like they could do with a nice coat of Satin Black or summink.
:conf:
:conf:
Me too, mine are half black, half metal in patches:conf:
So if Toyota's original's are £60 where can u get em cheaper
Matt
  • 2 years later...
Replaced the two rubbers for the f/screen and noticed that the prices and LH code had changed a little:
T85214-33050 LH4 - £5.09
T85214-30260 LH3 - £4.86
But, I got 20% discount today so, only paid £9.35 inc. VAT for some new wipers up front.
What a great design from Mr T :thumbs:
As the springs get older they won't push the rubber against the wind screen as well, this is particularly noticeable at speed. Mine currently lift off at around 90 on the drivers side. Wipers with spoilers will make the windscreen wiper stick to the windscreen at higher speeds. Thus saving you replacing the springs, i went to college for evening classes for a year and that's all i learnt :D
Is it just me, or are the springs in the metal arms of the wipers very weak, therefore putting little pressure on the wipers as they clear the screen?
New wiper arms are a lot better, I recently changed mine and it improved them a lot.
I can supply for £25 each for the front and £27 for the rear, plus postage, if needed.
For the winter a good coating of rain-x once a month works wonders. I recently changed all three wipers from Halfords but they do bosch wipers which are superior to any others I have tried. The drivers side comes with a spoiler and in a pack of two listed for the supra. The rear is not listed in their little book but you can match it size for size. It is a false economy to change only the blades because if the holder doesn't articulate properly thats when you get strips missing on your screen. £18:00 for the two front and £8:00 for the rear.:)
But if you know that the holder is just fine, it's very good VFM.
  • 1 month later...
