wHIZz Posted July 10, 2007 Share Posted July 10, 2007 Yep, I can confirm the freezer trick works (if it is still powering up). Have used it several times. Best to wrap it in a jiffy bag first - most recently I froze a 120GB Maxtor drive for 2 hours and got 30 mins use out of it - enough to get my data off. You will get condensation when you power it back up but I just wiped it every few minutes with kitchen roll! wHIZz Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted July 10, 2007 Share Posted July 10, 2007 Doesnt Lewis specialise in getting data back? Disclaimer - if Lewis does not specialise in data retrieval i apologise to him, his company and all his relatives inclusive but not limited to, his auntie Flo, uncle George, Nana and grandad and his pet goldfish Bubbles, Furthermore my speculation that the gentleman going by the pseudonym 'Lewis' in fact specialises in data retrieval was my own opinion and not that of mksupra.net, any of its moderators, site owners, or of Jelsoft enterprises Ltd, further details on request In addition to this, i would like to point out that if Lewis DOES indeed offer data retrieval that other data retrieval companies are available Thankyou Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted July 10, 2007 Share Posted July 10, 2007 yeah the freezer trick is a last resort. I think it can also help unstable chips run. Semiconductors become alot less resistive at low temps. Yep, I can confirm the freezer trick works (if it is still powering up). Have used it several times. Best to wrap it in a jiffy bag first - most recently I froze a 120GB Maxtor drive for 2 hours and got 30 mins use out of it - enough to get my data off. You will get condensation when you power it back up but I just wiped it every few minutes with kitchen roll! wHIZz interesting there's no sign of any burning on the pcb, it just doesn't spin up. will the freezer trick still work? Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted July 10, 2007 Share Posted July 10, 2007 Doesnt Lewis specialise in getting data back? Disclaimer - if Lewis does not specialise in data retrieval i apologise to him, his company and all his relatives inclusive but not limited to, his auntie Flo, uncle George, Nana and grandad and his pet goldfish Bubbles, Furthermore my speculation that the gentleman going by the pseudonym 'Lewis' in fact specialises in data retrieval was my own opinion and not that of mksupra.net, any of its moderators, site owners, or of Jelsoft enterprises Ltd, further details on request In addition to this, i would like to point out that if Lewis DOES indeed offer data retrieval that other data retrieval companies are available Thankyou Rob, you have way too much time on your hands thanks for the info though Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted July 10, 2007 Share Posted July 10, 2007 Rob, you have way too much time on your hands thanks for the info though Thats true, well bored Quote Link to comment Share on other sites More sharing options...
ozz Posted July 11, 2007 Share Posted July 11, 2007 Dropping it from a height of around 6-8 inches onto a hard surface can also help. As a last resort obviously, but it could free up the platters for data retrieval. The freezer thing does a similar thing and IIRC works by shrinking the internal parts allowing the platters to spin, usually lasts until the drive gets hot. And def stick it in a bag if you do that! I did have a guide to recovering hard drives, I'll look at home later. Rarely worth asking recovery specialists as most require hermatically (spelling?!) sealed labs and is therefore a very costly process. Quote Link to comment Share on other sites More sharing options...
Henk Posted July 11, 2007 Share Posted July 11, 2007 If it is your Windows XP boot disk, then try this: Boot up off XP CD, select 'R' for Repair At the prompt: FIXMBR CHKDSK /P Then try rebooting Quote Link to comment Share on other sites More sharing options...
Konrad Posted July 11, 2007 Share Posted July 11, 2007 If it is your Windows XP boot disk, then try this: Boot up off XP CD, select 'R' for Repair At the prompt: FIXMBR CHKDSK /P Then try rebooting This one is not spinning up, so I doubt any try with MBR will work. It's prolly fried board. Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted July 11, 2007 Share Posted July 11, 2007 tried the freezer trick got my fingers stuck to the metal casing.... that was about it i'll have to look out for the same drive so can rob the pcb Quote Link to comment Share on other sites More sharing options...
VIL Posted July 11, 2007 Share Posted July 11, 2007 Not wanting to plug my company.....but I will !! We deal with a company that can retrieve data from almost anything....even when you have lost all hope. If your interested in recovering the stuff I am sure we can help.. for more info go to our web site http://www.bluebeamsecurity.com/partner-fields-main.asp Quote Link to comment Share on other sites More sharing options...
grahamc Posted July 11, 2007 Share Posted July 11, 2007 Not wanting to plug my company.....but I will !! We deal with a company that can retrieve data from almost anything....even when you have lost all hope. If your interested in recovering the stuff I am sure we can help.. for more info go to our web site http://www.bluebeamsecurity.com/partner-fields-main.asp I just did an online quote with fields, and got quoted £300??!?! That seems a little steep. EDIT: just found the same drive on ebay for £5 so seeing if I can get that, change the board, and with a little luck..... Quote Link to comment Share on other sites More sharing options...
Marco79 Posted July 11, 2007 Share Posted July 11, 2007 I just did an online quote with fields, and got quoted £300??!?! That seems a little steep. EDIT: just found the same drive on ebay for £5 so seeing if I can get that, change the board, and with a little luck..... Got a quote from pc world and the robbing buggers wanted £600!! Now that is steep!!! Quote Link to comment Share on other sites More sharing options...
DJButler Posted July 11, 2007 Share Posted July 11, 2007 If it is your Windows XP boot disk, then try this: Boot up off XP CD, select 'R' for Repair At the prompt: FIXMBR CHKDSK /P Then try rebooting Bit of an old Dosser then Henk Quote Link to comment Share on other sites More sharing options...
VIL Posted July 11, 2007 Share Posted July 11, 2007 I just did an online quote with fields, and got quoted £300??!?! That seems a little steep. EDIT: just found the same drive on ebay for £5 so seeing if I can get that, change the board, and with a little luck..... MMMmm.... if your keen to recover the data PM the details of your drive and a breakdown of your issue and I will see what I can do on the price. Quote Link to comment Share on other sites More sharing options...
