How loud is an RSR Exmag GTII with double decat
spackrackman
Been offered a tootle around Donnington on a "quiet night" the noise restriction is 98 decibels. Its only 30 quid but if my exhaust is louder than that then there is no point as I wont even last a lap.
Double decat RSR Exmag GTII any ideas?
Many thanks
Jonnie
i have one cat removed and it was 102 db with my RSR, the other cat is coming out next friday......
Just out of interest, what revs was that at? MSV measured with the car stationary at 3/4 max rpm.
Interestingly they measured the bike at 1/2 max power rpm.
Oh yes. I remember hearing about that - can't recall why. EGTs ?
From another thread...
Putting a restrictor in the exhaust, just small enough to control boost on engines with overly small wastegates, isn't so bad, but adding further restriction to control noise is madness. Noise should be controlled by bigger silencers, or more silencers, or more efficient silencers. Ramming a bung in the tailpipe is about as crude as it gets, noise control wise, and can lead to sky high cylinder head and valve temps. If you want a quiet system with little restriction the Tanabe range has a superb system. i fitted one to Rush's car, and I am getting one for my Skyline, I was that impressed by it.
