Guest supraman1968 Posted July 9, 2007 Share Posted July 9, 2007 hi all, i ready to fit stainless exhaust and after market air filter to mt TT, will this cause over boosting as it did on my evo 6 before it was remapped or will this be ok, thanks Link to comment Share on other sites More sharing options...
supra_si Posted July 10, 2007 Share Posted July 10, 2007 supraman did you buy that TT from ebay?? i recognise it from a guy in lanarkshire selling that fine example. Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 10, 2007 Share Posted July 10, 2007 Search for BPU on here mate, that will explain all. Link to comment Share on other sites More sharing options...
jamesmark Posted July 10, 2007 Share Posted July 10, 2007 You will need to go FULL decat inc cat back exhaust to over boost tbh. You will need to fit a 1 bar or a 1.2 bar restrictor ring after the first cat to limit the boost. Then buy everything else for to go full BPU as mentioned above search for BPU and have a good read. Link to comment Share on other sites More sharing options...
Mas Posted July 10, 2007 Share Posted July 10, 2007 You will need to go FULL decat inc cat back exhaust to over boost tbh. You will need to fit a 1 bar or a 1.2 bar restrictor ring after the first cat to limit the boost. Then buy everything else for to go full BPU as mentioned above search for BPU and have a good read. all the above Plus dont bother with after market air filter as the stock air box does the job better than after market ones Link to comment Share on other sites More sharing options...
Guest supraman1968 Posted July 12, 2007 Share Posted July 12, 2007 bought stainless with de cat, where is best place to perchase restrictor ring and Fuel Cut Defender,thanks, also does the fcd need some sort of mapping or are they a easy fit and set up, Link to comment Share on other sites More sharing options...
jamesmark Posted July 12, 2007 Share Posted July 12, 2007 Get a Greddy one from Gaz @ Envy do not go for HKS, he probably has a restrictor ring aswell if not Email Chris wilson on here. The FCD is easy to fit and you can find instruction on here or @ http://www.mkiv.com Link to comment Share on other sites More sharing options...
Guest supraman1968 Posted July 12, 2007 Share Posted July 12, 2007 had a look ,only one they had was the HKS, can i ask whats wrong with this make.thanks Link to comment Share on other sites More sharing options...
Ric Posted July 12, 2007 Share Posted July 12, 2007 not very reliable or somthing, plus completely removes fuelcut where as the others dont, just higher it so there is still some protection Link to comment Share on other sites More sharing options...
