styggen82 Posted July 9, 2007 Share Posted July 9, 2007 HI, I am about to start intalling my Greddy BCC on a 98 supra vvt-i J-spec... Is the ecu wiring the same as described here; http://www.mkiv.com/techarticles/bcc/bcc_install/bcc_intro.htm will this work or need do I need another ecu diagram?? Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 9, 2007 Share Posted July 9, 2007 It is a very different ECU and the pinouts are way off. A jspec VVTi also uses a MAF sensor as well as the MAP sensor. I'm not 100% sure whether the BCC works on the VVTi or not. Quote Link to comment Share on other sites More sharing options...
styggen82 Posted July 9, 2007 Author Share Posted July 9, 2007 ok, thank god I haven`t started:) any one who have installed this on Jspec VVTI? Quote Link to comment Share on other sites More sharing options...
styggen82 Posted July 10, 2007 Author Share Posted July 10, 2007 anyone? If I find the correct wirings from the ecu, will the bcc do the job on my car? is there any other ways to get past 1 bar without fuel cut? Quote Link to comment Share on other sites More sharing options...
ivan Posted July 10, 2007 Share Posted July 10, 2007 Is this any good for you? Quote Link to comment Share on other sites More sharing options...
styggen82 Posted July 10, 2007 Author Share Posted July 10, 2007 Is this any good for you? Think so, have to study it abit to find out what wires I should tap in to.... but my bcc will work as long as I find the right wires?? Thanks for any help:d Quote Link to comment Share on other sites More sharing options...
Matti85 Posted July 10, 2007 Share Posted July 10, 2007 I was told the guide at mkiv.com should work for jspecs, mine is 93 TT and i posted this same question few days before, was told that this guide is what you ppl use to fitt the BCC on jspec. Quote Link to comment Share on other sites More sharing options...
Guest KILLERMRS Posted January 16, 2008 Share Posted January 16, 2008 Did it work? I have the same problem, but the Pinouts dont help realy. Does andybody know which one to cut for the Turbo Pressure Sensor? Thank you Quote Link to comment Share on other sites More sharing options...
styggen82 Posted January 16, 2008 Author Share Posted January 16, 2008 just use a multi-meter, and find the wire from the sensor on the manifold. trace it to the ecu, cut and install, tune it and boooooost:) it`s the center wire on the sensor, mine works perfect and I used the guide on mkiv.com, set it to 4,05 volt Quote Link to comment Share on other sites More sharing options...
Guest KILLERMRS Posted January 16, 2008 Share Posted January 16, 2008 Awsome, what Color does it have? Do you remember ;D Thank you Quote Link to comment Share on other sites More sharing options...
styggen82 Posted January 16, 2008 Author Share Posted January 16, 2008 brown and yellow I think but not sure, check the guide:search: Quote Link to comment Share on other sites More sharing options...
halllon Posted April 7, 2008 Share Posted April 7, 2008 When you guys say TPS - do you mean Throttle Position Sensor or Turbo pressure Sensor? I am struggling to find the correct wire myself. I can't see any yellow/brown wires in the guide, could it be either the yellow red or yellow blue? Quote Link to comment Share on other sites More sharing options...
styggen82 Posted April 7, 2008 Author Share Posted April 7, 2008 When you guys say TPS - do you mean Throttle Position Sensor or Turbo pressure Sensor? I am struggling to find the correct wire myself. I can't see any yellow/brown wires in the guide, could it be either the yellow red or yellow blue? http://www.mkiv.com/techarticles/bcc/why_bcc/tps.jpg wire nr 2 of the three that comes out of the turbo pressure sensor Quote Link to comment Share on other sites More sharing options...
Guest littlez Posted May 5, 2010 Share Posted May 5, 2010 hi there, i have a 98 vvti jpec and having troubles installing the BCC. I found the middle wire in the TPS its (black yellow for me)and installed the bcc like it says in the guide but now i have a malfunction and master warning lights going crazy on the dashboard. Can enyone help me please? Thank you Quote Link to comment Share on other sites More sharing options...
