TRD3000GT Posted October 19, 2004 Share Posted October 19, 2004 Ok boys and girls, I have a few issues comming up with MOT. My car still has cats so beofre you say, Its not one of them! I have always watched my car put on to a sort of roller thing where they test the brakes. This is normally a 3 inch drop and I know will end up damaging my doluck front. Is this needed as I just installed new UK's with brembos all round? Also what about the fog light I just got rid of at the rear? Not looking forward to a place asking me to put it back. Can any of these things be overlooked? Link to comment Share on other sites More sharing options...
LeeT Posted October 19, 2004 Share Posted October 19, 2004 the foglights easy. just get in touch with Emin and buy a taillight conversion kit from him so 1 of your brake lights doubles up as your fog light. Link to comment Share on other sites More sharing options...
absz Posted October 19, 2004 Share Posted October 19, 2004 hi there about your rear foglight its a must for mot test but only the drivers side. if your vehicle is lowered, then there is no reason why it has to be put in a brake tester roller the mot tester can use a device called a taply meter which is placed on the passenger footwell and the car is driven to 20mph and the brakes are applied to obtain a brake reading . all mot stations have a brake meter. Link to comment Share on other sites More sharing options...
Supragal Posted October 19, 2004 Share Posted October 19, 2004 Originally posted by absxxxx hi there about your rear foglight its a must for mot test but only the drivers side. if your vehicle is lowered, then there is no reason why it has to be put in a brake tester roller the mot tester can use a device called a taply meter which is placed on the passenger footwell and the car is driven to 20mph and the brakes are applied to obtain a brake reading . all mot stations have a brake meter. interesting. Chris- make sure you stay with the car at all times! Link to comment Share on other sites More sharing options...
Graham S Posted October 20, 2004 Share Posted October 20, 2004 Chris / supragal, they shouldn' t need to drive out of sight as like absxxxx said they only gotta do 20mph, You must be seriously low to get it stuck in the rollers, i've done loads of low cars with no problems, but better to be safe than sorry! I did Ashley W's supra with the bomex front and still had quite a few inches to spare, but i'm pretty sure the Do luck is quite a bit deeper. Good luck! Link to comment Share on other sites More sharing options...
Supragal Posted October 20, 2004 Share Posted October 20, 2004 I really meant stay with the car at all times in the viewing area or whatever. "err there appears to be a dent..." "that was there when you dropped it off" "no it wasn't" "yes it was" meh meh meh Link to comment Share on other sites More sharing options...
mr keef Posted October 20, 2004 Share Posted October 20, 2004 how much are them fog conversion kits? me aint got 1 either Link to comment Share on other sites More sharing options...
Supra ST Myster Posted October 21, 2004 Share Posted October 21, 2004 they are £22 which includes postage, comes with everything you need and full written instructions with pictures, or £35 for me to install it for you. Link to comment Share on other sites More sharing options...
Gordon F Posted October 21, 2004 Share Posted October 21, 2004 Originally posted by supra TT myster they are £22 which includes postage, comes with everything you need and full written instructions with pictures, or £35 for me to install it for you. Emin With your kit, does the 'bulb out' come on when you use the brakes with the fog lights on? Link to comment Share on other sites More sharing options...
Supra ST Myster Posted October 21, 2004 Share Posted October 21, 2004 The first kit i used to do did, the "bulb out" light only came on if you have the fog light on and then brake, but does go out if you switch it off, but i have worked on a new one which will not cause this anymore... Link to comment Share on other sites More sharing options...
