starter motor help!!!!
ukApache
i just spent the last hour getting the starter motor bolts undone after reading this thread: http://www.mkivsupra.net/vbb/showthread.php?t=51682 but now i cant seem to get it out i.e its no longer attached to the transmission but none of the gaps are big enough for it to fit through for me to take it away from the car. hope that makes sense :blink:
is there anything else that needs to be taken off like the fuel filter etc.
please help!! :(
If you've got an auto, it will come out if you line it up just right, with a manual,I have never managed to get one past the clutch slave cylinder yet. If you're replacing the solenoid contacts, just rest it on the subframe and do it there, its a fairly straightforward job.
