Disabling ABS from the cabin
cheekymonkey
I'd like to wire up a dash switch to turn ABS on and off so I don't have to remove or replace the fuse under the bonnet.
What's the best way of doing this? Looking at the wiring diagram I could just switch terminal A25 of the ECU which is battery voltage.
Wouldn't be looking to turn ABS off mid-journey but what would happen if I did? :)
  • 6 months later...
