Diffs! Confused!
cheekymonkey
My 6 speed *should* have an LSD, indeed it's indicated by the VIN plate.
When I jack up the rear and spin one wheel, the other wheel spins in the opposite direction. Searching this forum doesn't help as some people say that means LSD, others say no!
This was in gear mind - in neutral, both wheels are able to spin freely without affecting the other one. Is that normal?
Any ideas would be useful before I attempt to learn to drift next week :p
The torsen diff does something odd, since it is a torque sensing one, it needs power to distribute and turning a wheel by hand I don't believe would generate sufficient. I stand to be correct on this, as while I know what a torsen does and I'm unsure on exactly how it does it.
