ADD Posted July 4, 2007 Share Posted July 4, 2007 do i need a Restrictor ring in when im running hybrids @ 1.4 bar? or shall i have it taken out? i've used the new "USE ME" function and had no results. Any help would be great. Link to comment Share on other sites More sharing options...
Jake Posted July 4, 2007 Share Posted July 4, 2007 I guess it depends on whether they are UK spec based hybrids or j-spec based ones. Link to comment Share on other sites More sharing options...
ADD Posted July 4, 2007 Author Share Posted July 4, 2007 ah i see, i bought them off soop dogg and he got them off ian c...so if any one know which ones they are? Link to comment Share on other sites More sharing options...
grahamc Posted July 4, 2007 Share Posted July 4, 2007 jspec hybrids? uk hybrids? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 4, 2007 Share Posted July 4, 2007 I guess it depends on whether they are UK spec based hybrids or j-spec based ones. Why? as whether they are hybrid UK or J spec, both in theory should have modded/bigger compressor wheel, and if J spec the exhaust side should be metal, i doubt you will need RR more than likely a boost controller. Link to comment Share on other sites More sharing options...
ADD Posted July 4, 2007 Author Share Posted July 4, 2007 ok mate ive had a b/c installed with them. thanks for ya help mate Link to comment Share on other sites More sharing options...
Jake Posted July 4, 2007 Share Posted July 4, 2007 Why? as whether they are hybrid UK or J spec, both in theory should have modded/bigger compressor wheel, and if J spec the exhaust side should be metal, i doubt you will need RR more than likely a boost controller. Because the Jspec wastegate is smaller than the UK's one. Unless the JSpec WG has also been modified I shouldn't think it'll cope any better than they do on stock J ones. Link to comment Share on other sites More sharing options...
Class One Posted July 4, 2007 Share Posted July 4, 2007 If you currently run your car with an RR fitted, then I would keep it and use your ebc to up your boost. Soop Dogs was a GZ but i don't know if it was a Jspec or Uk car. I don't know if Ians is a Jspec or UK car. They were both running 550's and e manage on these turbos anyway with a EBC, so I would recommend that you do the same. Link to comment Share on other sites More sharing options...
ADD Posted July 4, 2007 Author Share Posted July 4, 2007 If you currently run your car with an RR fitted, then I would keep it and use your ebc to up your boost. Soop Dogs was a GZ but i don't know if it was a Jspec or Uk car. I don't know if Ians is a Jspec or UK car. They were both running 550's and e manage on these turbos anyway with a EBC, so I would recommend that you do the same. ok mate cheers, that exactly what im running too. thanks all Link to comment Share on other sites More sharing options...
Jake Posted July 4, 2007 Share Posted July 4, 2007 Soop Dogs was a GZ but i don't know if it was a Jspec or Uk car. All GZs are j-spec. Link to comment Share on other sites More sharing options...
Class One Posted July 4, 2007 Share Posted July 4, 2007 All GZs are j-spec. Learn something new every day. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 5, 2007 Share Posted July 5, 2007 Because the Jspec wastegate is smaller than the UK's one. Unless the JSpec WG has also been modified I shouldn't think it'll cope any better than they do on stock J ones. Good point, shouldn't have started drinking so early;) Link to comment Share on other sites More sharing options...
