2nd fan
Grazer
OK - I cut the hole in my NA shroud and put it all back together - but the 2nd smaller fan doesn't come on when I start the ignition.
Is it meant to come on immediately, or does it come on when things start heating up?
Everything seems to be wired up ok.
It comes on thermostatically m8
If you take the connector out from the bottom and tie it up it stays on all the time
:thumbs:
