SupraPL Posted July 3, 2007 Share Posted July 3, 2007 Hi. Any ideas guys? Maybe transmission oil cooler or torque converter (for example) can help to prolong the 5 speed's life? Tomasz. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted July 3, 2007 Share Posted July 3, 2007 I doubt a torque converter would do you any good on a Manual... Other than that I would have no idea how to beef it up, it just wasn't designed for huge power in the first place. Link to comment Share on other sites More sharing options...
Digsy Posted July 3, 2007 Share Posted July 3, 2007 Hi. Any ideas guys? Maybe transmission oil cooler or torque converter (for example) can help to prolong the 5 speed's life? Tomasz. Torque converter? On a 5-speed? Link to comment Share on other sites More sharing options...
tDR Posted July 3, 2007 Share Posted July 3, 2007 Search for an OS Giken gearset for it? That's what the SX boys do with their feeble 5-speed transmissions when going for decent power. Or convert to a 300ZX box, the equivalent in our world would be an R154 5-speed swap outta a mk3 Supra Turbo - think BL offer a conversion kit as it's a decently beefy trans without the silly cost associated with the Getrag 6-Speed. Cheers, Brian. Link to comment Share on other sites More sharing options...
Stevie Boy Posted July 3, 2007 Share Posted July 3, 2007 Torque converters for Auto transmissions only dude. A cooler would need some form of pumping of the gear oil to and fro cooler and probly wont make much difference. Maybe a rebuild with replacement gear set like straight cut gears and new synchro's these would cost a fortune plus new bearings. Dunno how available these bits would be for but reckon you'll be forking out £3500+ in bits alone! Is it worth it. Check out Pfitzner Performance Gearbox http://www.ppgearbox.com.au They do a 5sp Dog Box for W series Supra..... weighs in at £3176.26 just for the gearsets from a UK distributor! Ouch! Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 Search for an OS Giken gearset for it? That's what the SX boys do with their feeble 5-speed transmissions when going for decent power. Or convert to a 300ZX box, the equivalent in our world would be an R154 5-speed swap outta a mk3 Supra Turbo - think BL offer a conversion kit as it's a decently beefy trans without the silly cost associated with the Getrag 6-Speed. Cheers, Brian. I can't afford to do 6-speed conversion, besides my goal is only 450hp at flywheel. I will try to find OS Giken gearset. Thanks Tomasz Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 I can't afford to do 6-speed conversion, besides my goal is only 450hp at flywheel. I will try to find OS Giken gearset. Thanks Tomasz I found it there: http://www.xspeed.com.au/shop/product_info.php?cPath=42_116&products_id=757 How much is it in £? Link to comment Share on other sites More sharing options...
RobSheffield Posted July 3, 2007 Share Posted July 3, 2007 Is that definitely the right one? £612.833 according to XE.com Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 Is that definitely the right one? £612.833 according to XE.com I don't know Rob. OS GIKEN - Close Ratio Gear Sets - Model Supra - Set of 3 Gears $1,446.99 +$1,128.01 (?) Sub-Total: $2,575.00 Link to comment Share on other sites More sharing options...
tDR Posted July 3, 2007 Share Posted July 3, 2007 Bloody good price but wrong listing: TOYOTA 7M-GTE / 1JZ-GTE 3 Close Ratio Gears 1st, 2nd, 3rd That uprated gearset is for the mk3 Supra R154 box! Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted July 3, 2007 Share Posted July 3, 2007 That's for the 7M-GTE though. Not one available for a MKIV, not even the 6 speed. Beaten to it. Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 Bloody good price but wrong listing: TOYOTA 7M-GTE / 1JZ-GTE 3 Close Ratio Gears 1st, 2nd, 3rd That uprated gearset is for the mk3 Supra R154 box! That's for the 7M-GTE though. Not one available for a MKIV, not even the 6 speed. Beaten to it. So can i do anything more than perfect maintenance for my gearbox? Link to comment Share on other sites More sharing options...
Lebsteif Posted July 3, 2007 Share Posted July 3, 2007 On the supraforums is the rumour that a 5sd gearbox from a certain type of lexus is stronger than oure mkiv 5spd tranny;s. Can;t find the specific topic back but perhaps you can open a topic there as well? Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted July 3, 2007 Share Posted July 3, 2007 Best to find a gearbox from the MKIII as has been suggested. Link to comment Share on other sites More sharing options...
JODY T Posted July 3, 2007 Share Posted July 3, 2007 Why not drive it untill it breaks! Then buy another one.. they are cheap to buy and fairly easy to get hold of... They dont take long to fit either! whilst doing that save your cash for a 6speed.. Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 On the supraforums is the rumour that a 5sd gearbox from a certain type of lexus is stronger than oure mkiv 5spd tranny;s. Can;t find the specific topic back but perhaps you can open a topic there as well? Done. Why not drive it untill it breaks! Then buy another one.. they are cheap to buy and fairly easy to get hold of... They dont take long to fit either! The only problem is that i live in the middle of nowhere and i don't know any good car mechanic. Any more ideas lads? Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 3, 2007 Share Posted July 3, 2007 So can i do anything more than perfect maintenance for my gearbox? Basically, no, not unless you get into fancy heat treatments and stuff, but that'll cost more than a six speed conversion. One day you will see the light and sell this car Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 3, 2007 Share Posted July 3, 2007 Done. The only problem is that i live in the middle of nowhere and i don't know any good car mechanic. Any more ideas lads? You may also see the light and move somewhere closer to the civilized world, where mechanics are used to fuel injection and not fixing horses and carts It's also warmer in the lowlands. Link to comment Share on other sites More sharing options...
RobSheffield Posted July 3, 2007 Share Posted July 3, 2007 Perhaps if you link in to the US supraforums post you made for future reference - i tried to find it, but its not easy Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 Basically, no, not unless you get into fancy heat treatments and stuff, but that'll cost more than a six speed conversion. One day you will see the light and sell this car I just took my car off the for sale section. Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 Perhaps if you link in to the US supraforums post you made for future reference - i tried to find it, but its not easy No problem mate. http://www.supraforums.com/forum/showthread.php?p=5300483#post5300483 Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 You may also see the light and move somewhere closer to the civilized world, where mechanics are used to fuel injection and not fixing horses and carts It's also warmer in the lowlands. LOL I will move out from Inverness probably in April/May 2008. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 3, 2007 Share Posted July 3, 2007 I just took my car off the for sale section. Seriously Tomasz, I'd just see how the stock box lasts, with a sprung plate clutch and sensible driving it should be OK with the torque levels you are aiming for. Link to comment Share on other sites More sharing options...
SupraPL Posted July 3, 2007 Author Share Posted July 3, 2007 Seriously Tomasz, I'd just see how the stock box lasts, with a sprung plate clutch and sensible driving it should be OK with the torque levels you are aiming for. Seriously Chris, This car is only my toy. I'm not using Supra for commuting or long trips so predictable annual mileage will be around 3-3.5k miles. I will change gearbox oil (Motul Gear 300) twice per year. 400fwhp every day (0.8bar), 450fwhp from time to time. No burnouts, no "shots from a clutch". I bought RPS Max Clutch with Street Disc. Is it a good clutch? Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 3, 2007 Share Posted July 3, 2007 Has it got a sprung driven plate? They take a lot of the shock loads out in normal driving and help protect the drivetrain from harmonics. Link to comment Share on other sites More sharing options...
