djskeme Posted July 2, 2007 Share Posted July 2, 2007 Hi guys, When i start my engine from cold, it starts at 1500rpm as normal, and all sounds good. As it starts to drop, and the engine begins to warm, there is this noticable rattly/tinny kinda noise which initially sounded like a spark plug rapidly sparking.....but the car isnt misfiring at all. When I put my foot down to give it more revs...the clicking/tapping/rattle picks up and is louder and more obvious.....until the car is warm and has been driven for a bit. Then it completely goes away. I have a couple of suggestions to what i thought it could be but im less than technical 1. heatshield 2. poor spark plug connection 3. Problem with one of the cats 4. some kind of rattle from somewhere. The only one that seems feasible is the cat ... as once its fully heated up it performs as normal? Anyone offer any more help? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 2, 2007 Share Posted July 2, 2007 Can you actually hear it from inside the car when driving, if not i suspect all you are hearing is the injectors ticking, as they are about the most noisy part of the engine. Quote Link to comment Share on other sites More sharing options...
djskeme Posted July 2, 2007 Author Share Posted July 2, 2007 When the engine is warm.....and running properly....the car is perfect, humms nicely and is faultless. its so loud you can hear it inside the car, and under acceleration is really really loud! Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 2, 2007 Share Posted July 2, 2007 where abouts in surrey are you? Quote Link to comment Share on other sites More sharing options...
djskeme Posted July 2, 2007 Author Share Posted July 2, 2007 croydon, why? Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 2, 2007 Share Posted July 2, 2007 If you'd have been closer (to Guildford) i'd have popped over (if you wanted) to try to pin point (or at least eliminate) something. Quote Link to comment Share on other sites More sharing options...
djskeme Posted July 3, 2007 Author Share Posted July 3, 2007 i'd say id meet you half way, but then it would be warm and wouldnt show you the noise....no one else got any ideas? Quote Link to comment Share on other sites More sharing options...
djskeme Posted July 8, 2007 Author Share Posted July 8, 2007 as a development to this, it seems to be from just behind the top glove box ... which is the back right of the engine bay. It seems to go after more braking is done...could it be something to do with air in the brake system or possibly something to do with the heater matrix? all the cool air and hot air is fine. Sorry im not technical just suggestions Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted July 9, 2007 Share Posted July 9, 2007 Mine used to do this but mine was the exhaust heat shild on the second cat section of the exhaust. By the sound of yours it may be something different. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted July 9, 2007 Share Posted July 9, 2007 I would be 99% certain it the cat....get it out (the cat that is) as it can be detrimental the the running of the car esepcially if the inside has aged considerably and it causing a restriction to exhaust gases Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 9, 2007 Share Posted July 9, 2007 I would be 99% certain it the cat....get it out (the cat that is) as it can be detrimental the the running of the car esepcially if the inside has aged considerably and it causing a restriction to exhaust gases I'm 99.9% certain it won't be the cat breaking up... But there again I was certain enough to wager a fiver on Alonso winning the British GP.... Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted September 8, 2008 Share Posted September 8, 2008 (edited) i had this today, first time ive heard it, car been standing for 3days, started up drove straight off and had this tapping ticking noise for about a quater mile. started car later in work for the trip home and nothing, the car sounds sweet as a nut. very strange. i thought it was pinking/engine knocking, scared the crap out of me as i dont wana be fixing this thing, £££££ Edited January 14, 2010 by supraGZaerotop (see edit history) Quote Link to comment Share on other sites More sharing options...
Dazzi Posted September 9, 2008 Share Posted September 9, 2008 This happened to me. The heatshield on the 1st cat was one rattle and the exhaust bracket attached to the gearbox was another - the metal snapped on the bolt and was rubbing together. Quote Link to comment Share on other sites More sharing options...
Guest [S]oLiD Posted September 9, 2008 Share Posted September 9, 2008 if its coming from the passenger side corner, it could be your charcoal canister, they tend to tick like crazy...... Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted September 9, 2008 Share Posted September 9, 2008 I'm 99.9% certain it won't be the cat breaking up... But there again I was certain enough to wager a fiver on Alonso winning the British GP.... oooo dare I disagree with Mr Wilson im going to on this one...just this once. Im still betting on a cat/exhaust related noise Quote Link to comment Share on other sites More sharing options...
monkey3 Posted September 9, 2008 Share Posted September 9, 2008 Could be air \ coolant going through the heater matrix (or the power steering (but not as likely)). This sort of fits your symptoms. Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted September 9, 2008 Share Posted September 9, 2008 it was loud enough for my to hear it over my radio, it wasint turned up loud or nothing but still. i drove off from my home and could hear it, so i stopped and put it in neutral(autobox) and gave it a rev and could hear it very clear, sounded like a sort of tap tap tap tap tap tap. the exhaust gasket/turbo/manifold sounds stop on to me, as the supra get warm very quickly and gone in under mile if that.it is worring when you hear these strange noises. Quote Link to comment Share on other sites More sharing options...
UltraFlynn Posted September 9, 2008 Share Posted September 9, 2008 Check the stabiliser which connects to the 1st cat. Mine broke and once the car warmed up made a hell of a rattle. Quote Link to comment Share on other sites More sharing options...
R Black Posted September 9, 2008 Share Posted September 9, 2008 Mine taps over 2k occasionally from start up, can only hear it if passenger windows open & the noise bounces of a wall or something, usually stops Posted via Mobile Device Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted September 20, 2008 Share Posted September 20, 2008 well its been 2 weeks and nothing, i think i know what it was. the only thing that i did before it made this noise was clean my engine bay, i sprayed a little silicone on the plastic bits to clean them up, also spray a little over the cam cover, what i think happened was spray got in thru the vent in the cam cover and on to my coilpack connectors and it was arcing slightly, im convinced it was this, been perfect ever since. dont spray any aerosol cleaners near the coilpack connectors, they dont like it. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 20, 2008 Share Posted September 20, 2008 What you will have done is got some silicone on the auxiliary drive belt, which has quietened it. Some make God awful noises when they wear or become dry. If it starts again spray a touch on the belt with the engine running, it'll stop straight away. Quote Link to comment Share on other sites More sharing options...
