Nitrous boost switch - what are you using?
SimonR
Sweet! You're pretty handy at this interweb. Thanks.
More than welcome RS electronics is a goldmine of bits and pieces, find just about anything.
With the pressure gauge, and the activation switch, I consider putting in some sort of basic comparator circuit.
if wot AND boost THEN fire solenoid.
not to highjack,
but how much was you nos kit i got a quote of 670 for a full kit with a controller (from NOS)
i've seen kit with out got for 800 (wizards of NoS),
surely with a controller is better as you csna fine tune to your driving style or it all coming in at 1000rpm :)
not to highjack, but how much was you nos kit i got a quote of 670 for a full kit with a controller (from NOS)
I paid £308 for a dry kit from Cold Fusion. That's including bottle, purge kit and p+p from Texas.
I wouldn't pay that much for a wife let alone a nitrous kit.
surely with a controller is better as you can fine tune to your driving style or it all coming in at 1000rpm :)
Dunno, this will be my first nitrous kit so I won't know until I've got some experience.
Couple of points..
1. You might have hassles getting the bottle filled if it does not have an EU safety mark on it (Yes, I got caught out with this).
2. Be careful with a dry kit... you might have issues with running lean with the fuel
3. A progressive controller is a very good idea if you are going to go slightly bigger jets.
Um...the kit has arrived and the bottle doesn't have any EU markings. I assume from your comment that suppliers can be precious about this.
Still, there are no such things as problems - only opportunities. This must be a common opportunity and I'm guessing that the easiest fix would be to do my own label with a EU mark. A quick rummage on the interweb hasn't revealed anything readily available. Is it just a case of sticking on a separate EU sticker or am I likely to have to forge a complete label from a compliant bottle? Who has done this and do you have a scan or at least a close-up pic that I can create my own label from?
It all depends on the filler, most people should we say we will overlook it, however some may get funny...
Just try it, and see how it goes..
It isn't a label, it is an etching into the bottle usually.
For all the hassle you are going to with pressure switches and logic circuits you may as well just run it off the E-Manage's sub injector driver :)
If the 5v driver can't run it, use it to trigger a fast switching relay that controls a 12v feed to the solenoid. That way you've got boost *and* rev windowing and you can pulse/stage it too with different duty cycles. I'm sure Gav could magic up a suitable relay, and that's all it'll cost you :thumbs:
-Ian
The bottle needs a "pye" (like the maths symbol) mark on it to be EU certified. will be inscribed into the bottle probably next to the serial number. im gonna try these when i fill up as i have american nitrous express bottles....
http://cgi.ebay.co.uk/Nos-Nitrous-Oxide-Refills-10-11-Lbs-Wizards-NX-NO2_W0QQitemZ220125943339QQihZ012QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
-Ian
Yes, I'd already thought of doing that but I assumed that I'd need something to convert the 5v signal to some form of solenoid control.
Gav?
send away your bottle and get it back bit risky
Here is the a few to choose from
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?D=solid%20relay&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&Ntk=I18NAll&Nty=1&Ntt=solid%20relay&Dx=mode%20matchpartial&Ntx=mode%20matchpartial&N=0&name=SiteStandard&forwardingPage=line&R=2508802501&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0912415356.1183571335@@@@&BV_EngineID=ccdkaddlgelghejcefeceeldgondhgj.0&cacheID=uknetscape
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?D=solid%20relay%205v&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&Ntk=I18NAll&Nty=1&Ntt=solid%20relay%205v&Dx=mode%20matchpartial&Ntx=mode%20matchpartial&N=0&name=SiteStandard&forwardingPage=line&R=2509033807&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0912415356.1183571335@@@@&BV_EngineID=ccdkaddlgelghejcefeceeldgondhgj.0&cacheID=uknetscape
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?D=solid%20relay%205v&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&Ntk=I18NAll&Nty=1&Ntt=solid%20relay%205v&Dx=mode%20matchpartial&Ntx=mode%20matchpartial&N=0&name=SiteStandard&forwardingPage=line&R=2509033920&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0912415356.1183571335@@@@&BV_EngineID=ccdkaddlgelghejcefeceeldgondhgj.0&cacheID=uknetscape
This one is probably the best bet.. Can handle 5A on the output side, runs happily on a switching voltage of 5v
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?D=solid%20relay%205v&Nr=AND%28avl%3auk%2csearchDiscon_uk%3aN%29&Ntk=I18NAll&Nty=1&Ntt=solid%20relay%205v&Dx=mode%20matchpartial&Ntx=mode%20matchpartial&N=0&name=SiteStandard&forwardingPage=line&R=2508806840&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0912415356.1183571335@@@@&BV_EngineID=ccdkaddlgelghejcefeceeldgondhgj.0&cacheID=uknetscape
http://docs-alliedelec.electrocomponents.com//Images/Products/DataSheets/821-8202.pdf
10A DC version in the same series - http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?obs=sObs&name=SiteStandard&No=0&N=0&Ntk=I18NAll&Ntt=G3NA-D210B&Nty=1&D=G3NA-D210B&Ntx=mode%20matchpartial&Dx=mode%20matchpartial&callingPage=/jsp/line/line.jsp&BV_SessionID=@@@@0912415356.1183571335@@@@&BV_EngineID=ccdkaddlgelghejcefeceeldgondhgj.0&cacheID=uknetscape&Nr=avl:uk
Easy to wire in as well, - to ground and + to the 5v switching output of the emanage. The load side can go directly to the solenoids then.
Me!!
Sorry mate!
I looked at those items and there's a lot of electrobabble that's over my head. All I want is a relay that will switch according to an input voltage between 0v and 5v. Doesn't have to be scalable in any way, I just need to know what voltage the relay would require me to send from the Emanage. I would then wire the relay in with the NC as part of the nitrous circuit so that the voltage that I send will switch the relay to NO, thereby breaking the circuit and cutting off the nitrous.
Can you advise which one of those would fit the bill?
Gav,
At the risk of making myself appear even thicker than usual, from the wiring diagram below the 3 would be the 0-5v from the Emanage, the 4 would be ground and the 1 and 2 would form part of the circuit for the NOS? The 1/2 would be closed until a certain voltage was sent to 3?
This is the diagram for the G3NA-205B.
Gav,
Don't panic, don't mind the questions.
Yes, 4 would be ground, and 3 the emanage connection. I need to check the datasheets to confirm what the default state is off the unit, I believe it could normally open till voltage applied, but I will confirm.
