Wanted: Air con pump
SteveR
Was at Chris Wilson's for a basic service yesterday and he spotted that my aircon pump is making 'orrible noises and on its way out - suspected worn bearings.
Can these be refurbished, or replaced in part, or do you have to swap in a full replacement unit?
Assuming it's the latter, anyone got an air con pump kicking about that I can buy?
Cheers!
Steve
I should have a good used one at work, call me tommorow Steve0121 7074554
Bugger, I've only just seen this Ibrar - I'll call you on Tuesday mate :)
Don't have acecss to the site from work as our company firewall recorded too many swear words and now it's blocked :(
Ibrar... He's a "good guy"
I've had dealings with Ibrar in the past and totally agree with you Chris. :)
It would be excellent if (and I mean if) you can sort the drain, replace & refill too, Ibrar - I know it's not your usual line of work so won't expect anything... just the replacement unit on it's own would be extremely welcome! :)
Steve,
I do all aircon work that incudes repairs, just done a compressor on a Saab 95 and what a job that was :blink:
The Supra compressor is alot easier in comparison.
I can send the compressor to Chris, if you want Chris to carry out the work.
Steve,
Actually mate you're a lot nearer and easier for me to get to - I'll give you a call tomorrow and see what we can sort out for when I get back from the 'Ring. You're a lifesaver! :)
my air con pump seized so i had to replace mine, i was told if you catch it early enough you can have them refurbished, its the bearings that go in them, its a comand fault on the supes, new air con pumps are about £860 from Mr Ts main dealer part only i was told so i got a second hand one from jezzbabes for £100
