Anyone upgraded/replace the HD in a Sky+ box?
Jake
The HDD is my Sky+ box has started making a horrible noise. It's the poxy little one that can only store about 20 hours of programs so I thought I might as well have a bash at upgrading it to a newer and bigger one.
Anyone here done this already? I'm sure there's How To guides on the net for this but thought I'd ask here for real life experiences too.
Yup, did mine a while back when I was still using it.
Works a treat actually, didn't have ANY problems with it, just make sure you pick a drive that works. I used a slightly taller drive, and I added a cooling fan just to make sure as they have a habit of overheating (The original reason for replacing the fireball drive)
Still got my old sky+ system without a drive sat somewhere..
If I did that I don't remember doing it. I just put the drive in, and then went into the installer menu (think it is 0 - 1 on the system) and did a system reset which formats the drive and stuff.
Unlike Tivo, sky+ doesn't store it's OS on the drive, but rather in flash. The disk is purely used for video storage.
My non-computer-literate brother did his a few months ago.
If he can do it you should have no problem Jake. :)
Thanks Ken :)
Yeah, did it last night. Works fine. Bit noisy though.
ive been thinking about doing this aswell
are there any limitations?
drive speed storage capacity
Apparently 5400rpm drives are best because they're quieter. I can;t see why you'd need more than a 160Gb HD but you can put 250 or 500gig ones in if you want.
Thanks Ken :)
I thought there was a size limit on the size of the drives you can install in the Sky+ boxes, 160gb rings a bell, is this right?
I've been thinking about doing this for a while but I need to a) get a drive and b) get the misses to stop taping so much frikkin crap to allow me to swap it out :D
There is some software somewhere, that allows you to copy the existing data over to the upgraded drive...
