Removing small windows
jazz1
they are bonded in you will need a thin long blade of some desciption (i used one of those extending blade plastic knives) slice away at the bonding take your time and dont try and force it as someone on here smashed one and they aint cheap
Guest gzaerojon
get yourself down to your local fishing tackle shop and buy some trace wire (used for eel fishing) if you can thread it though a part of the sealant then you can saw it backwards and forwards while working around the window.
you'll need to stop when you get to one of the bolts holding the glass in then insert the wire the other side and keep going
hope that helps :)
