Water Injection
Whitelightning
I am researching a water injection system.
Has anyone done this ?
I realise the Aquamist system is a market leader.
Has anyone got the ECU controlled 2C system ?
Did it plug into your existing ECU/after market ECU ok ?
What real results did you get using this ?
I know Paul at whiffbits has one on his Supra - any comments Paul ?
IMO there is absolutely no need fopr a mapped system. How would you map it anyway? There's no way you could map it on the road or rollers, something like WI mapping needs to be done on a proper engine dyno where other temp issues can be totally controlled. Mapped WI is really strictly full race engine territory run to the very limit. I can sell you a mappable system, as i can any Aquamist product, i just don't think you need it ;)
The basic 1s system run off the supplied pressure switch, which I usually set at 10 psi, should be totally adequate.
Below is a short article I wrote last year on WI, it may be of some interest. I can do you an excellent price on Aquamist WI if you decide that's what you want. Cheers.
Water injection serves 2 closely related functions on a turbo engined
car. Firstly it cools the charge air temperature by utilising an effect
known as the latent heat of evaporation. This property can be self
demonstrated very easily. If you pour something that evaporates quickly
like petrol on your hand it feels very cold. This is the rapidly
vaporising spirit removing heat from your skin and bloodstream by the
aforementioned process. By spraying a very finely atomised mist of water
into the inlet of a turbo engine when under boost conditions the
evaporation of the water into steam causes a temperature reduction in the air and
fuel intake charge. A cold charge is less likely to be subject to
detonation than a hot charge. A cool charge is also denser, able to
carry more air and fuel mix per unit of volume. These 2 properties of
water injection allow either less chance of detonation at a given boost,
maybe allowing lower octane fuel to be used, or to allow a rise in boost
pressure usage without detonation. These are very desirable goals for
any modifier of a turbo engine, or one using an engine mapped to run
on a higher octane fuel than generally available in the UK. Japanese
import turbo cars for example.
People ask whether squirting water into an engine causes corrosion. In
fact this is not a problem, the combustion temperatures under boost
ensure the water is turned instantly to steam and is ejected out of the
exhaust. The water mist is injected only when high boost is sensed via
a supplied pressure sensor switch. The basic combustion process of
hydrocarbon fuels causes LOTS of water to be generated anyway, which is why cars
not driven on regular long journeys will rust out a mild steel exhaust
system from the INSIDE out. If water is added in the correct volume, via
the supplied, calibrated jets, this is not a problem.
Even when used alongside a larger or more efficient intercooler, or
indeed when an intercooler is used in an application where one was not
present as standard, water injection can and does increase charge cooling
still further. Water can be stored either in the existing windscreen
washer bottle or in a separate, dedicated, container. In cold conditions
it is essential to add an anti freeze additive to the water to stop pump
damage through freezing. Windscreen washer additive serves this purpose
fine and the engine won't mind ingesting this solution at all. Or you
can add neat methanol, which is usually the anti freeze additive in
washer fluid anyway. Using a 50 / 50 percent by volume water / methanol
mix will actually help increase the octane of the intake charge, as an
added benefit. As a yet further advantage the latent heat of evaporation
of methanol is extremely high. A win / win situation. It is not however
obligatory to use methanol as an additive. All components of the water
injection kit that are in contact with the fluid are stainless steel or
able to tolerate water and methanol or screen washer additive without
degradation. A properly set up system does not use a vast amount of
water, in fact a modern car sized screen washer bottle used also for the
water injection reservoir will suffice admirably. A water filter is
included to keep any sludge out of the pump or jet. This should be
checked regularly for contamination and blown out if residue is
apparent within.
Hey Chris,
If you have a mappable ECU like the AEM you could setup another map that runs closer to 12.5afr when the WI is activated, this could be done automatically or with a manual switch.
I know that if the pump failed or you ran out of water the AEM would need to sense this and go back to the normal map which is shouldn`t be difficult to setup, you could also get it to monitor switch on IAT and EGT as well.
Surely running 12.5 instead of 11.5 should release some nice power or is it minimal?
:thumbs:
i have it on mine fitted by chris, its an extra bit of safety. going to have a methanol tank on mine rather than just washer jet water.
worth it for peace of mind
the one you want seems a bit ott. you could also run with better fuel if you racing.
aquamist is not that expensive to buy.
  • 6 months later...
erm, just been told by someone in work about this system...
I thought they were on about the water spray system like some of the Imprezas have where water is sprayed onto the intercooler.
I can't belive this system injects water into the engine, surely this is the one thing you never want to do with any engine.
I always thought - Water in engine = Engine going to go bye bye's.
You guys really think its a good mod to do?
Whitelightning and anyone else who is interested, check out the following link
http://www.waterinjection.info/phpBB2/
This will take you to Waterinjection Forum where they discuss all the systems including all the ERL Kits. You may be surprised but they are doing some wicked stuff with the kits and it has definitely helped me to get the best out of my system 1 Kit
Cheers
I think I am going to get a decent aftermarket IC spray kit now. This should also help with the engine temp I would of thought, plus, it will help increase performance as it will provide the IC with more cooling effect, therefore, condensing the air more.
Anyone fitted one of these yet?
I've also experimented with W.I. a wee bit (not on the Supra yet though)
Tried different nozzles, mixtures, locations, orientations, if you can imagine it I've probably tried it.
Hell, even tried nitromethane for a short while before it went kaboom, lol...
