Freeze on way - Coolant
Chase
OK, heard earlier that there is (supposedly) some cold weather coming shortly and we may be in for a chilly winter.
With this in mind, does everyone have sufficient antifreeze in their coolant? Anyone what the mixture should be and what the correct fluid to use/not use is?
Cheers
Quoting the manual:-
Use a good brand of ethylene-glycol base coolant and mix it according to the manufacturer's directions.
Using coolant which includes more than 50% ethylene-glycol (but not more than 70%) is recommended.
NOTICE:-
Do not use alcohol type coolant.
The coolant should be mixed with demineralized water or distilled water.
Personnally I use 4life all year round but it is a bit expensive.
EDITED to say 4life comes premixed.
