Guest gzaerojon Posted July 1, 2007 Share Posted July 1, 2007 still on 29 Link to comment Share on other sites More sharing options...
RedM Posted July 1, 2007 Share Posted July 1, 2007 25 is nuts. The exit is on a island and no way to get across without removing the square needed to manover on the end square. The trick is to not activate the X until later! You need to do some to'ing and fro'ing. Link to comment Share on other sites More sharing options...
ivan Posted July 1, 2007 Share Posted July 1, 2007 Level 33? Rough guide: From the start, enter the main area, down and around Os in the middle and then back up to the top left, across the top to the right, down slightly but then head back up to the sticky out bit near the top in order to adjust the point at which you start down the right hand side. Once you've got your positioning right the rest is dead simple. Hit the X and retrace your steps.Cheers Martin. I'll give it a go in a bit. Link to comment Share on other sites More sharing options...
RedM Posted July 1, 2007 Share Posted July 1, 2007 Cheers Martin. I'll give it a go in a bit. It takes 69 moves to do the last level. Should be a good guide to how well you are doing. Link to comment Share on other sites More sharing options...
ivan Posted July 1, 2007 Share Posted July 1, 2007 Sorted, thanks. Yep, it was fairly easy after all. I think I was a bit too brandy laden by the time I got to that level last night. Link to comment Share on other sites More sharing options...
Jive Posted July 1, 2007 Share Posted July 1, 2007 Ok, I'm completely stuck on this level 448106 about stage 13 I think. Can't for the life see how you get across the single track at the back of the puzzle nor the front bits help! Link to comment Share on other sites More sharing options...
ivan Posted July 1, 2007 Share Posted July 1, 2007 You have to approach the top right by rolling up sideways (turn round on the large patch below). Then you're in the right place to miss both the orange squares. Then make your way down the LH side. You need to end up stood on the grey square below the bottom-left most orange square. Drop forward and roll across to the right then stand up. Drop left, roll once and you'll end up standing on the lone grey square. Drop forward and you're done. Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted July 1, 2007 Share Posted July 1, 2007 i need to do it a few less moves now lol Link to comment Share on other sites More sharing options...
Suprash Posted July 1, 2007 Share Posted July 1, 2007 Ok, I'm completely stuck on this level 448106 about stage 13 I think. Can't for the life see how you get across the single track at the back of the puzzle nor the front bits help! Im sure I know what level that is before I even look Jive, it took me a while, but there is a way you can position the block along the back that it will fall long ways over both orange tiles.... EDIT: Doh, should have read the rest of the thread first, lol..... Link to comment Share on other sites More sharing options...
Jive Posted July 1, 2007 Share Posted July 1, 2007 Thanks Ivan and Ash, finally done it even though I did fall off the edge at the bottom once Link to comment Share on other sites More sharing options...
