Bloxorz
michael
Nope, don't see the solution to that one. :(
I can't get to the X without stepping on an O. :(
Level 33?
Rough guide: From the start, enter the main area, down and around Os in the middle and then back up to the top left, across the top to the right, down slightly but then head back up to the sticky out bit near the top in order to adjust the point at which you start down the right hand side.
Once you've got your positioning right the rest is dead simple. Hit the X and retrace your steps.
