Ibrar Jabbar Posted June 29, 2007 Share Posted June 29, 2007 Can anybody help with what is required to power my AC machine which has an output of 700W. Will a inverter do the trick or is a small generator more suitable? Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 29, 2007 Share Posted June 29, 2007 You can hire a power supply Ibrar? Its £60 + VAT I think... Gaz. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted June 29, 2007 Author Share Posted June 29, 2007 Is that from JAE Gaz? and is it a generator you get? Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 29, 2007 Share Posted June 29, 2007 Is that from JAE Gaz? and is it a generator you get? Hi Ibrar, Yep. Its a mains hookup - literally a plug Do you need an industrial connection for equipment etc? Gaz. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted June 29, 2007 Author Share Posted June 29, 2007 I only need domestic 240V off a plug, is the power restricted to certain areas? Link to comment Share on other sites More sharing options...
JustGav Posted June 29, 2007 Share Posted June 29, 2007 Get a small genny... something around the 1kw should be sufficient... Cheap enough, I think macro had them for around the £150 mark. Link to comment Share on other sites More sharing options...
