who's the best to change a supra to uk fuel
satansbodyguard
You do not need to change it, Japanese fuel nowadays is 100 ron, engines were built to run on 95 ron(our standard unleaded) but you will get less performance and it may run rough, use shell v power which is 99 ron or bp ultimate 97 ron or tesco 99 ron if you can get it, i only use v power ,ultimate if i have to, if your car is n/a and not tt then you will be fine with 95 ron, although i would always use higher octane for personal preference
mmmmm.... Any idea where the 100 ron thing came from then
Old Wives Tale...
Internet "Fact"
Bloke down the pub....
Pick any one of them...those that have been to Japan should be able to confirm or deny, Nick and Gaz (Envy) have been there...
don't use normal Unleaded.
As said above, dont run it on normal unleaded, 99 from tescos, BP ultimate or similar only, performance decrease from using 95 octane fuel is the least of your worries when getting on boost
