non turbo performance!!
Guest shielsy
A more reasoned answer for the poor fella:
Written by me for someone wanting to tune a 4 cylinder fuel injected Opel engine, but the EXACT same principles apply to all modern multi valve N/A units.
Post the early eighties,more and more manufacturers went to electronic
management of ignition and fuel,via fuel injection,and mapped ignition
systems. Most fuel injection systems had one immediate impact. They no
longer need a restrictive venturi (narrow throat) in the carburettor
(s) to pull fuel out of the fuel bowl of the carb. Fuel injection
*injected* the fuel under high or very high pressure. No restriction as
such,and hence less of a power loss. Management of the ignition and
fuel suddenly meant engines could get away with running camshafts with
greater overlap,and higher lift,too. The old advance weight disi,and
velocity sensitive carb limited what cam profile could remain
driveable, without hesitations,poor low end performance and flat
spots. To a large extent electronic management allowed much more
freedom in valve sizes,port shapes,and cam timing,as well as running
the engine at the best amount of ignition advance at all loads and
RPM's without detonation,on differing fuel qualities,via knock sensor
technology.
What I am slowly getting at is that it is *much* harder to get
anything like a useful power gain from a modern,well designed,16 valve
production engine on electronic management. The exhausts are free
flowing,as are the intake systems. One needs to look at further
performance optimisation of the cam profiles,and maybe bigger
valves,stronger valve springs,moves away from hydraulic valve lifters
and mechanical improvements to make higher revs safe,from a
mechanical stress related point of view. Almost any change that has the
potential for a marked improvement in power and torque,will require
different fuel curves (the amount of fuel injected at any one set of
parameters of air flow,temperature,engine RPM etcetera,etcetera),and
different timing curves. One can fudge the fuel,*across the whole
curve*,by increasing fuel pressure via an "up rated" fuel pressure
regulator,but the the weeks of dyno testing to get the fuelling
correct at every point,has then gone to pot ... :-(
As for the ignition,there is very little indeed you can do to change
the curve incrementally. Unfortunately,the *correct* answer is an
aftermarket injection system,or at least an aftermarket ECU and
wiring,that allows one to map the curves afresh,to suit your new power
modifications. This is expensive,both in terms of hardware,(maybe over
£1000 for the ECU and wiring loom),plus a lot of professional engine
dyno time to get it all mapped correctly.
Sometimes one can buy a complete package,say new cams,different
throttle bodies and manifold,etcetera,that can come complete either
with a modified EPROM for the existing ECU,or an aftermarket mappable
ECU complete. If one limits mods to exactly those which the kit
manufacturer intended,this should work well. If you change any
parameter from the tuners package,the early comments about incorrect
curves again apply..
Changing the exhaust *system* or the air filter,on 90% of modern
engines will do sod all.The mags claim this and that,but in reality a
gain of 5 HP on a 120 HP engine is neither here nor there,for a road
car. Humidity variations can see that much change. A rolling road is
hard pressed to accurately repeat to 5 BHP on a figure of 120 HP
total. To get greater gains,say 20 HP,you need to look at fairly
dramatic alterations,both to the mechanical components,and their
related fuelling and ignition curves.
Turbo engines are a slightly different kettle of fish,as it is trivial
to raise the boost,and usually to fudge some additional fuelling.
Naturally aspirated remain tricky!
The easiest/cheapest way to see increased performance is to reduce
weight. Especially rotating weight,for improved acceleration. Do most
people ask the most important question when buying new wheels,after
ensuring the offset and sizing is correct? Do they *uggery :-) They
should take a fishermans scales with them,and weigh the damned
things. The first question a race car manufacturer asks his potential
wheel suppliers is what do they weigh,and what is their rotational
inertia. Simple questions,and the weight,if not rotational inertia,is
easily self assessed performance differences can be
surprising,and worthwhile. Given 3 different makes of tyre,with similar
grip and handling characteristics,go for the lightest..Just weigh some
of the cheap imported tyres against a decent performance make,like a
Hoosier competition tyre that is road legal. The difference is
amazing. As for remolds,they are incredibly heavy.
If you are serious,and can live without goodies,buy a car with the
minimum spec. Sun roofs,air con,PAS,electric windows and mirrors,power
seats all can add hundreds of pounds. Lightweight front seats can add
as much performance,in real terms,as a new exhaust and manifold. 40
pounds of fancy stereo gear does nothing for performance ;-)
As cars become better,and more highly developed,the art of tuning
their engines becomes more complex and expensive,unless one looks at
the situation with a bit of lateral thinking. Instead of adding
things,think in terms of removing them. Instead of buying a new set of
wheels just for their looks,weigh them,and see if a gain can be had
for free there.
Just ideas,some may be practical for your situation,some not,but be
aware it is all too easy to buy so called performance bits,and get the
thing to go *slower* At least the engine in your car starts off as
one of the best basis for tuning available.
If someone asks about performance and na supras, then it's only fair to let them know what they could have. Otherwise they may end up regretting it - what if they don't want a reliable daily driver that can be out-accelerated, out-braked, and out-handled my most modern hot hatches? :innocent:
I bought my NA because I was put off by so many comments about the TT breaking down. I'm really happy with her - she doesn't feel that fast but as I think I got 3 points recently thats probably a very good thing! I was also actually put off by people saying just how well they perform as I like to push my cars and I think you could come seriously unstuck with a RWD TT.
I get a similar arguement in work from my mate who has a scooby. A 'faster' scooby passed him the other day he's totally gutted and looking to upgrade his turbo. I tried to convince him that he should buy a car for himself, not because its faster than x model. ATEOTD, no matter what you get, someone is going to have something faster so you are always going to dissappoint yourself.
My missus lost all interest in fast cars when she bought a motorbike...
Out of interest, UK model aside - does the TT have better brakes and suspension than the NA then?
tbh, its all been said. The NA came out of the factory with around 220bhp as standard. Time will whittle this down to around 200bhp. About the only usefull mods you can do to liberate a few more ponies is to fit a full after market exhaust system, remove both cats, and.....erm, thats about it.
Mr T's stock air induction system is better than most aftermarket kits - fitting a different one can actually restrict the air flow;)
You can throw silly money at an NA but the most you'll get out is another 20 or 30bhp. Better you keep that money and buy a stock TT. You'll be looking at around 320bhp and can BPU it for a grand or so :)
L
If you can get your NA engine close to factory stock and by the same token a 13 year old TT would drop from 320bhp to say 300BHP, the difference is only going to be 80bhp. And given the NA delivers its power much more smooothly than a TT, the NA will be 5 miles down the road before the tired old TT has hit boost, or whatever it does when the turbos work. So at the end of the day an NA would get from A to B quicker than a TT. Yaboo hiss to all you TT boys
Hmm I said the exact same thing when i joined but soon relised theres not much point. Kind of a waste of money when u can go buy the TT and work on that!
i agree, i bought an n/a without doing the research. got bored of it and got a tt:)
not really some na's have the 'uk' brakes as do some tt's........and again 'yellow' bilsteins are the best factory dampers and are on some NA's and TT's.........
NB uk cars have the softest least sporty suspension of the lot......
me too..............this is the normal progression for NA owners........
I would always advocate owning a TT just for the giggles.........my first drive and more memorably the various first times for friends and family where just so funny........truely awesome performance.
Doesn't make the NA bad, I still have a hoot in mine its just as capable (better even?) handling wise and is even nice to drive enthusiastically all year round whatever the weather.
I have to ask, what's with all this bollocks about TT's breaking down?
I was 'lurking for a while on here before buying my supra. The majority of fault threads seemed to relate to the TTs, very few in comparison for the NAs.
Now that maybe because more TT owners mod their cars hence potentially causing more problems, or it could be that they are not as reliable as the NA.
I also talked to members of other jap sites who had experience with supras and the theme that came through was that you needed deep pockets to run the TT, similar to the GTO's that I looked at.
With so many people talking about reliability there must be something in it - perhaps you are one of the lucky ones!
Perhaps someone should do a poll!?
I had the same issues when I owned an E36 325, everyone raved about the M3. It looked the same, cost more and unless you drive like you stole it everyday didn't hugely differ?
Perversly I would love the TT just for the noise you can get from the turbo and dump valve, but thats the child in me!
i think its the modding that does it.......
For 10+ yr ols sports/GT cars they are both fantastically reliable IMO. A bpu'd tt is asking a bit more from the turbo's and this will accelerate the wear on them...........also upping the boost with say poor intercooling and spark plug selection and you can risk the engine.
As is always stated there is little you can do to a NA engine so they are all well within their normal/designed operating envelope.
They are less sensitive to 'on the dot' servicing and will take a bit of neglect better without causing problems IMO.
There's plenty you can do to an NA, but it just requires deep pockets to get any meaninful gains, it's no different to tuning any other NA car, be it an M3, a 911 or a Griffith. You can use a stand alone EMS, bigger injectors, the naughtiest cams you can get your hands on, bigger valves, bigger inlet plenum, gas flowed and ported heads, hike up the compression, use stronger rods and lighter pistons, beefier bearings, tubular manifold & free flowing exhaust, hike up the rev limit to 8500rpm- the list goes on, it's just that you've sunk £20k for another 100bhp.
Oh and I'm not lucky, just chooey about where I get my car serviced and don't boost my turbos beyond their caperbilities.
Regarding the 325i vs M3 argument- I've never met anyone who has owned an M3 then gone to the same E-series non M version. My bro has owned E36 318iS, 328 sport and now a 3.2 Evo, there is no way he'd trade down, the Evo isn't just a 328 with another 100 horsepower, it's a totaly different experiance altogether.
