Guest shadowake Posted June 27, 2007 Share Posted June 27, 2007 Hi after I do about 5 miles a big red triangle with an exclamation mark in the middle of it pops up in the rev counter any idea what this means, also after about 10 miles a light randomly flashes saying slip cont off Any help apreciated. Quote Link to comment Share on other sites More sharing options...
wallace9 Posted June 27, 2007 Share Posted June 27, 2007 Have a look here http://www.mkivsupra.net/vbb/showthread.php?t=35920&highlight=CHECK+ERROR+CODES Quote Link to comment Share on other sites More sharing options...
stevie_b Posted June 27, 2007 Share Posted June 27, 2007 Hi shadowake, Look up the error code(s) like wallace9 suggested. My guess is that it'll be code 42 (speed sensor error). If so, there are *loads* of threads that discuss code 42 on here, and don't worry, you probably won't need a new speed sensor! PS in future, you might get more technical responses posting in the "supra chat" section rather than "new members" Quote Link to comment Share on other sites More sharing options...
carl0s Posted June 27, 2007 Share Posted June 27, 2007 Hi after I do about 5 miles a big red triangle with an exclamation mark in the middle of it pops up in the rev counter any idea what this means, also after about 10 miles a light randomly flashes saying slip cont off Any help apreciated. Is your ODO connected and working properly? Quote Link to comment Share on other sites More sharing options...
Guest shadowake Posted June 27, 2007 Share Posted June 27, 2007 Could it be something to do with my speedo being changed to mph and delimited? Quote Link to comment Share on other sites More sharing options...
wallace9 Posted June 27, 2007 Share Posted June 27, 2007 From what I've read about code 42 its most likley to be caused by that. Check your error code just to make sure Quote Link to comment Share on other sites More sharing options...
stevie_b Posted June 27, 2007 Share Posted June 27, 2007 Could it be something to do with my speedo being changed to mph and delimited? Quite possibly. Best to check what the error code is first, but if it is code 42, then a faulty Digital Speed Converter (DSC) and Top Speed Delimiter (TSD) are often the culprits. A faulty DSC caused mine. Quote Link to comment Share on other sites More sharing options...
Guest shadowake Posted June 27, 2007 Share Posted June 27, 2007 OK cheers guys I'll take a look at her when I get home from work, I'll let you know what I find! Quote Link to comment Share on other sites More sharing options...
