Supra ST Myster Posted June 26, 2007 Share Posted June 26, 2007 Ok, so what do you think of this, i have made a small slim line box which consists of 2 blue 7segment LEDs.. One of the 7 Segment LEDs tells you what gear you have selected from the auto lever, and the other actually shows you what gear the auto box is actually in, so for instance, you select Drvie, the left LED will show D, and if the box is in 4th the right one will show D, but when you kick down the right one will then show 3 and so on.. Be good to monitor the box selection i think? Would people be interested in this? As will be applying for a hobbyist soon and this is one of the things that will be on there.. Link to comment Share on other sites More sharing options...
Ian W Posted June 26, 2007 Share Posted June 26, 2007 I don't get it Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 26, 2007 Author Share Posted June 26, 2007 which bit dont you get? Link to comment Share on other sites More sharing options...
Ian W Posted June 26, 2007 Share Posted June 26, 2007 which bit dont you get? i get it now it's for when it's being used in Auto mode so you can see which of the gears you're using. for some bizarre reason i was thinking "but you can see which gear you're in when you select it" never mind Link to comment Share on other sites More sharing options...
hoff Posted June 26, 2007 Share Posted June 26, 2007 I like it. Nice idea. Link to comment Share on other sites More sharing options...
AndyT Posted June 26, 2007 Share Posted June 26, 2007 Nice idea. Would be interested to see that in action. Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 26, 2007 Author Share Posted June 26, 2007 i will be posting up a small video of it working in action soon. Link to comment Share on other sites More sharing options...
hadyn Posted June 26, 2007 Share Posted June 26, 2007 I like the sound of this. How much would it cost and would it be easy to fit? Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 26, 2007 Author Share Posted June 26, 2007 It would need to be wired into the Auto ECU and then a power supply point. Pretty easy install, Cost would be £25 plus p&p Link to comment Share on other sites More sharing options...
silvershark44 Posted June 26, 2007 Share Posted June 26, 2007 What does it look like? Link to comment Share on other sites More sharing options...
Matt H Posted June 26, 2007 Share Posted June 26, 2007 sounds good! i like you idea, be ace if you could incorporate it into the dash thingy dials! Link to comment Share on other sites More sharing options...
hadyn Posted June 26, 2007 Share Posted June 26, 2007 It would need to be wired into the Auto ECU and then a power supply point. Pretty easy install, Cost would be £25 plus p&p Im deffo up for that. Would be ace If you need a test guinea pig, Im your man Link to comment Share on other sites More sharing options...
hoff Posted June 26, 2007 Share Posted June 26, 2007 Good price. Im intrested. I look forward to seeing the video. Link to comment Share on other sites More sharing options...
RedM Posted June 26, 2007 Share Posted June 26, 2007 Surely if you are in a scenario where you may have kicked down to 2nd or 3rd you really should be looking at the road and not at a display. Link to comment Share on other sites More sharing options...
Guest Geneb Posted June 26, 2007 Share Posted June 26, 2007 interested bud Link to comment Share on other sites More sharing options...
Al Massey Posted June 26, 2007 Share Posted June 26, 2007 Surely if you are in a scenario where you may have kicked down to 2nd or 3rd you really should be looking at the road and not at a display. yeah but its the flashy light thingy that looks cool and add to the gadgets Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 26, 2007 Author Share Posted June 26, 2007 Surely if you are in a scenario where you may have kicked down to 2nd or 3rd you really should be looking at the road and not at a display. its only for monitoring so you dont have to look at it all the time, but im sure you can manage to be able to take a quick glance.. Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 26, 2007 Author Share Posted June 26, 2007 the size of it is approx 30mm high, 50mm wide and 70mm long.. just has the 2 blue seven segment LEDs on the front, and the wire loom comming out the back, may install an on off switch also. Link to comment Share on other sites More sharing options...
supra matt Posted June 26, 2007 Share Posted June 26, 2007 sounds good to me mate , ill take one if you make them Link to comment Share on other sites More sharing options...
dangerous brain Posted June 26, 2007 Share Posted June 26, 2007 Now this would be a trick addition to the defi HUDs you can buy. Sell your idea to that lot lol. Must admit I would like a HUD level reading of what gear I have selected as I often go a bit crazy and go from D to N. Could this device possibly be stuck into a 52 or 60 mm circular face and mounted in an A-pillar pod? Obviously not for £25 but its a thought if you are gonna go hobbyist. Link to comment Share on other sites More sharing options...
Class One Posted June 26, 2007 Share Posted June 26, 2007 Emin if you need a test bed? Anyway count me in I'm interested. Also need to sort out a date for doing the white leds as discussed. Link to comment Share on other sites More sharing options...
flukey-lukey Posted June 26, 2007 Share Posted June 26, 2007 Waiting for video c'mon hurry up and get it sorted Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted June 26, 2007 Share Posted June 26, 2007 Me too subscribed ;-) Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 26, 2007 Author Share Posted June 26, 2007 Emin if you need a test bed? Anyway count me in I'm interested. Also need to sort out a date for doing the white leds as discussed. Yes mate, cheers, yeah, i cant do this weekend or the next for the LEDs but after that is ok, let me know on that one.. Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 26, 2007 Author Share Posted June 26, 2007 Now this would be a trick addition to the defi HUDs you can buy. Sell your idea to that lot lol. Must admit I would like a HUD level reading of what gear I have selected as I often go a bit crazy and go from D to N. Could this device possibly be stuck into a 52 or 60 mm circular face and mounted in an A-pillar pod? Obviously not for £25 but its a thought if you are gonna go hobbyist. Thinking about it there is no reason why i cant extend the cables going to the two seven segment LEDs so if thats the case then they can be mounted in the gauge cluster or as you ask a 52/60mm circular face and insert it onto the A pillar hole depending on which one you have. Link to comment Share on other sites More sharing options...
