Guest bowman Posted June 25, 2007 Share Posted June 25, 2007 My brother has just ordered a set of 19" rims 8.5 front 9.5 rears. Rears having 275/30/19 tyres. The guy has told the rears are to big and will foul the arches (I think this is poo), and he has offered him a set 8.5 front and rear with 235/35 instead. Which would be alot cheaper. I feel the bloke is trying it on...... Can any one comment, sorry i dont know the offset. thanks in advance! Quote Link to comment Share on other sites More sharing options...
mr lover Posted June 25, 2007 Share Posted June 25, 2007 i run 19's with same tyre but it will depend on the offsets, you do not want 235 on the back though Quote Link to comment Share on other sites More sharing options...
Steve Posted June 25, 2007 Share Posted June 25, 2007 I run 19's, again with the same size tyre. They have never rubbed and the car is slightly lowered to Quote Link to comment Share on other sites More sharing options...
Guest bowman Posted June 25, 2007 Share Posted June 25, 2007 standard is usually around 35-40. Do you have much clearance? Quote Link to comment Share on other sites More sharing options...
2JG Posted June 25, 2007 Share Posted June 25, 2007 i've got 10.5 inch rears with a +47 offset running 295/30's. admittadly i did have to get the arches rolled. as gary has said, i think the 275/30's will be fine. Quote Link to comment Share on other sites More sharing options...
mr lover Posted June 25, 2007 Share Posted June 25, 2007 do you know what wheels they are? Quote Link to comment Share on other sites More sharing options...
merckx Posted June 25, 2007 Share Posted June 25, 2007 I've got 19's , 8.5" front and 9.5" rear 275/30 on the rear, offset +37 245/35 on the front, offset +39 No problems with rubbing. Quote Link to comment Share on other sites More sharing options...
AndyT Posted June 25, 2007 Share Posted June 25, 2007 My brother has just ordered a set of 19" rims 8.5 front 9.5 rears. Rears having 275/30/19 tyres. The guy has told the rears are to big and will foul the arches (I think this is poo), and he has offered him a set 8.5 front and rear with 235/35 instead. Which would be alot cheaper. I feel the bloke is trying it on...... Can any one comment, sorry i dont know the offset. thanks in advance! He's tryin' it on. Rear wheel drive car should have wider on the rear. I'm running 8.5 / 9.5 18's because I went for the handling + style. I know of a fair few people running 19's but nobody will defineately comment on handling, so I went safe. Even during fitting the guys slagged me for not having 19's instead. Looks = 19 Handling = 8.5 / 9.5 's.18's or 8 + 10's x 18's. 265's on 9.5 rims are no problem with clearance, 275's could be problematic but don't think so. Apparently the offset for the 8.5 and 9.5 is just about perfect fot stock arches. It certainly looks it. Quote Link to comment Share on other sites More sharing options...
AndyT Posted June 25, 2007 Share Posted June 25, 2007 I've got 19's , 8.5" front and 9.5" rear 275/30 on the rear, offset +37 245/35 on the front, offset +39 No problems with rubbing. First time I've seen definitive figures for 19's. Thanks. Quote Link to comment Share on other sites More sharing options...
danny_silva Posted June 25, 2007 Share Posted June 25, 2007 i have 19" to.. 265x30 on the back and 235x35 on the front!! dont know offsets but no problem with arches!! Quote Link to comment Share on other sites More sharing options...
4leks Posted June 25, 2007 Share Posted June 25, 2007 i also have 19" 275x30 & 235x35 Quote Link to comment Share on other sites More sharing options...
Blackie Posted June 26, 2007 Share Posted June 26, 2007 i run 19's with same tyre but it will depend on the offsets, you do not want 235 on the back though why dont you want 235 on the back? Quote Link to comment Share on other sites More sharing options...
Guest bowman Posted June 26, 2007 Share Posted June 26, 2007 i would nt want my brother to spend a grand on wheels that dont fill the arches properly. My first thoughts were that he cant honour the price he quoted. thanks for the advice guys. Quote Link to comment Share on other sites More sharing options...
mr lover Posted June 26, 2007 Share Posted June 26, 2007 why dont you want 235 on the back? too small, standard is 255 Quote Link to comment Share on other sites More sharing options...
Jake Posted June 26, 2007 Share Posted June 26, 2007 too small, standard is 255Not on the NA. Quote Link to comment Share on other sites More sharing options...
SuperSupraNA Posted June 27, 2007 Share Posted June 27, 2007 NA 16\" standard is 245 NA 17\" standard is 255 for the rears, 235 is too small Quote Link to comment Share on other sites More sharing options...
Jake Posted June 27, 2007 Share Posted June 27, 2007 NA 16\" standard is 245 NA 17\" standard is 255 Were 17" wheels ever standard on the NA? I thought upgrading to TT size wheels and tyres was an optional extra. Quote Link to comment Share on other sites More sharing options...
Guest bowman Posted June 27, 2007 Share Posted June 27, 2007 rear offset is 25mm! thats why the gut thinks they will be problematic Quote Link to comment Share on other sites More sharing options...
Guest bowman Posted June 27, 2007 Share Posted June 27, 2007 right....... 25mm offset is going to foul the arches. I dont think there will be enough lip to grid away to fit them, rolling them nearly always results in rot a year or so later... so dont want that. so we are going will the 8.5 front and rear with 37mm offset. Rears will be spaced by them by 10mm or so, and will be fitted with a 255/30/r19, so although the rim with be the same width the tyres will be wider.... cheers guys.... Quote Link to comment Share on other sites More sharing options...
Andrew_sup Posted June 27, 2007 Share Posted June 27, 2007 it got 255's on the back of my n/a the look nice and wide no trouble at all with them and my dad dave has 18" with 255's on back and his supras decked no problems there ethier. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 27, 2007 Share Posted June 27, 2007 Could he not just get wheels with the right offsets? Quote Link to comment Share on other sites More sharing options...
hoff Posted June 27, 2007 Share Posted June 27, 2007 My N/A came with 215/45/17 fronts and 235/45/17 rears. Im about to either change them or get a set of 18s. Either way they're going. Ive not driven a supra with the propper sizes on but i hope its better. Those sizes are not good for the handling as far as i can tell. 235/45/17 and 255/40/17 for sure unless i go for the 18s when it'll be 235/40/18 and 255/35/18. Think thats right and wide enough. Quote Link to comment Share on other sites More sharing options...
turbonut Posted June 27, 2007 Share Posted June 27, 2007 Interesting (and timely for me) post. My NA is sitting on: Front - 225/40R18 - 8 Rear - 255/35/R18 - 8 Although it handles well with no oversteer, the rears need to sit further out to fill the arches better, probably by another 10mm. If I had the dosh, 19" would definitely look better, with more offset. Weather or not you feel your choice affects your handling only you will be able to tell. Hope it works out well, you seem to have made your decision anyway L x Quote Link to comment Share on other sites More sharing options...
hoff Posted June 27, 2007 Share Posted June 27, 2007 I think so Linda. A bit dissapointing not to see any on sunday. But I think I'll push the boat out and go for some volks or rays:) Quote Link to comment Share on other sites More sharing options...
Guest bowman Posted July 2, 2007 Share Posted July 2, 2007 Brothers wheels are on, look great. Will upload pics soon. Maybe 10mm spacer on rear to realy fill the arches! Quote Link to comment Share on other sites More sharing options...
